PROPEX HS2000 Forced Air Propane Furnace With Thermostat!
Postby Cosmo » Tue Nov 08, 2016 8:52 pm
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Re: PROPEX HS2000 Forced Air Propane Furnace With Thermostat
Postby Shadow Catcher » Tue Nov 08, 2016 9:22 pm
About $600 to $700 coming from the UK.
Postby GuitarPhotog » Wed Nov 09, 2016 12:09 am
6500 BTUs is a crapload of overkill for most trailers.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Esteban » Wed Nov 09, 2016 1:37 am
www.westyventures.com/propex imports and sells Propex heaters.
Propex Heatsource furnaces
The perfect cabin heating solution for campervans, small RV's, pop-up campers, and small boats
We are the US importer and warranty center for these heaters - buy from the source!
Steve - SLO, CA
Esteban
Images: 15
Postby Cosmo » Wed Nov 09, 2016 2:46 am
External air intake and exhaust for the combustion chamber vents propane combustion fumes and moisture to outside the sleeping cabin. I like the safety aspect.
"In addition to passing strict European standards the furnace’s intelligent electronics constantly monitor the operation of the heater to make sure everything is operating perfectly. The flame, case temperature, combustion airflow, gas solenoid valve and voltage are scanned continuously. If a problem is detected the heater will instantly switch off and the red light on the thermostat will flash to let you know there is an issue."
Temp Control.
"The solid-state electronic thermostat is an easy to fit surface mount design. It automatically switches the unit on and off to maintain the desired interior temperature. When the temperature drops below the selected level, the HS2000 will automatically ignite and run until the cabin reaches your ideal temperature. The intelligent electronics use minimal electric current during ignition so cycling the HS2000 on and off does not have the effect of additional battery drain".
Cosmo
Postby MtnDon » Wed Nov 09, 2016 5:47 pm
Those are nice heaters. A friend has one in a van conversion.
MtnDon
Images: 24
