tire wear
tire wear
Postby PKCSPT » Fri Nov 11, 2016 6:31 pm
Went for a quick overnight and noticed my driver side tire is wearing uneven. The inside tread is almost gone where the outside is still pretty fair. Tires are 7 years old and I need to replace them Antwan but why the odd wear. The right side is wearing evenly. I crawled underneath and didn't see anything loose or broken.
2009 Little Guy 4 wide.
121172 116946 159644
PKCSPT
Images: 61
Re: tire wear
Postby lfhoward » Fri Nov 11, 2016 8:05 pm
I would guess you might have a bad wheel bearing on the side with the uneven tire wear. If the wheel is not perfectly vertical and it is sticking out more at the bottom than the top, then there would be more weight and friction on the inside of the tread. Jack up the trailer, place a jack stand under the axle, then grasp the wheel with both hands and try to wiggle it. If there is any play it would indicate a bad bearing. Spin it too to see if it spins freely or if there are any noises that shouldn't be. The hub might also be hot to the touch after driving.
lfhoward
Re: tire wear
Postby GuitarPhotog » Fri Nov 11, 2016 8:12 pm
Or it may be that the axle is bent and that wheel doesn't track parallel with the other.
Regardless, 7 years old is too old for tires, please replace both.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: tire wear
Postby lfhoward » Fri Nov 11, 2016 8:52 pm
Good point, Chas. That would certainly do it.
lfhoward
Re: tire wear
Postby PKCSPT » Fri Nov 11, 2016 8:59 pm
I kept an eye on the hub on my way home, or should I say hand feeling for any heat. It was cool on both sides. Yes 7 is as far as I will push any tire no matter how good it may look. I will jack it up tomorrow and see if there is any wobble, visually tire looks as straight as on the other side. Thank you for the suggestions, I hope it's not the axle.
PKCSPT
Images: 61
Re: tire wear
Postby PKCSPT » Thu Nov 17, 2016 10:08 pm
I took it to a tire store, new tires, bearings repacked. They did not see a bend in the axle, tire moves evenly, no tilt, but I am still suspicious. Come spring I will have it looked at again.
PKCSPT
Images: 61
Re: tire wear
Postby swoody126 » Fri Nov 18, 2016 9:35 am
if you are still concern'd give this a try
jack both tires off the ground and secure on jack stands under the axle where the suspension is bearing the load as it would running down the road
take a piece of tape and place it across the tread on each tyre
put a mark on the tape on each tyre
w/ a helper get on the ground and measure the distance between the marks
do this 3 times
horizontally at the mid point front & rear as well as at the very bottom
if your tyres are completely under the frame during normal travel measure at the top vertically centered
if you get the same measurement at all 4 points you have zero camber & zero caster
anything other than the same measurement will tell you where your issue(s) are/may be
the issue you described could be something as simple as a loose bearing(the axle nut has excessive play)
if there is just a slight bit of bearing wear it can relax the adjustment/tension on the axle nut and allow the wheel/tyre to ride just a bit off true causing the result you experienced
at each fuel stop i use the back of my hand to check the temperature of the tyres, my finger tips to check the temperature of the hubs and grab the top of the tyre and try to wiggle it in & out
if the back of a mother's hand is good enuff to tell the temperature of the milk she is feeding her infant it is good enuff for tyres
your finger tips should be able to detect any differential in hub temps
and if the bearings are the least bit loose your hands will feel and your ears will hear a bit of a clunk
of course it is never wrong to jack each tyre off the ground and spin it at the beginning of the season or b4 a trip, listening for a gravely growl emitted by wonky/dry bearings. no growl no foul :thumbsup:
you said NEW TYRES installed & BEARINGS REPACKED so...
GOOD LUCK
sw
swoody126
