Trailer Hitch Holes not there?
Postby greenchicken » Sat Dec 29, 2018 12:55 pm
Hi,
Finishing the trailer assembly and either I am not understanding or something is wrong with my part.... I assume it is the latter.
Looks this picture. The hitch has to holes on top that had bolt already installed connected to the chain.
But there are no matching holes.
Screen Shot 2018-12-29 at 10.30.09 AM.jpg (240.83 KiB) Viewed 619 times
greenchicken
Re: Trailer Hitch Holes not there?
Postby redbicycle » Sat Dec 29, 2018 1:17 pm
It looks like the holes are on the side?
redbicycle
Postby Graniterich » Sat Dec 29, 2018 1:18 pm
I have seen this before, they assume the long bolts all the way through Will be strong enough, kinda like pins.
Sent from my A1-840FHD using Tapatalk
Graniterich
Postby KTM_Guy » Sat Dec 29, 2018 4:05 pm
Probably a generic ball coupler that has holes in the top and side predrilled. Did the give you bolts for the side holes?
Todd
KTM_Guy
Images: 193
Postby Padilen » Sat Dec 29, 2018 6:14 pm
Through the side is recommended and I believe "legal". Through the top is not recommended, I'm not sure if it's legal.
Last couplers I've bought do not have those 2 holes. I've seen them in the past, a tack well has been used to hold them onto tongue. I assumed, holding it as tongue was drilled.
Padilen
Postby edgeau » Sun Dec 30, 2018 2:46 am
Can yours go on like this?Image
Sent from my Pixel using Tapatalk
edgeau
Postby swoody126 » Sun Dec 30, 2018 8:22 am
interestingly there are MANY trailer tongues(tilting boat trailers) that are only held w/ one 5/8" horizontal bolt
the average 2" receiver hitch is only held in place by one 5/8" pin
the smaller square receivers use a 1/2" pin
your hitch assembly includes two horizontal bolts which will be more than adequate
sw
swoody126
