Time for a new stove.
Postby Modstock » Sun Feb 03, 2019 3:59 pm
It's time to replace our old green 2 burner stove. It's getting old, dirty and has taken a beating over the years.
We are looking at the Colman stove/grill combo. The only issue I see is the aluminum grill. There was a review I saw that the grill had melted trying to boil water.
Also when I got our "Pie Iron" , I was told to avoid the aluminum made unit and find the cast iron version. This is my only 2 concerns about this.
Do any of you have this grill/stove combo ???
Thoughts , etc.
Sent from my H1611 using Tapatalk
Modstock
Re: Time for a new stove.
Postby Greg M » Sun Feb 03, 2019 6:59 pm
I’ve been using one for several years now with no problems. I also got the skillet top for pancakes etc.
Greg M
*Geek Extraordinaire
Images: 85
Postby halfdome, Danny » Sun Feb 03, 2019 8:02 pm
There's been some controversy over the years about harmful effects of cooking with aluminum.
To be safe, I got rid of everything in the kitchen that's made out of aluminum.
Others may not agree, but you can never be too careful, especially when other products are available.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby tony.latham » Sun Feb 03, 2019 8:31 pm
My concern would be how easy it is to clean if you actually grill on it.
As far as aluminum and health, the Alzheimer's Association calls that Myth #4.
https://www.alz.org/alzheimers-dementia/what-is-alzheimers/myths
But I can't remember where I heard that... :frightened:
Postby KennethW » Sun Feb 03, 2019 8:40 pm
I too am going with a replacement for my old Coleman with a KampKook. Ha haImage
145993
KennethW
Images: 82
Postby gudmund » Sun Feb 03, 2019 11:30 pm
but YES !! Aluminum melts at much lower temp's than steel/cast iron. Don't remember the temp, but it is at a much lower temp and that 'melting' temp is close to being achievable on a camp-stove if left on the burner too long!! Steel/cast iron 'melts' at much higher temps - less chance of them melting - but all of these items - no matter the type of medal - can be damaged by too high of heat being used - warping, etc .............
found out the temp's: Aluminum melts at about 1200 degrees - where Cast Iron's melt temp is 2200 degrees - steel 2500 degrees - note: these temp's are for melting, "warping" damage happens at lower temp's, before the 'melting' temps are reached ........................
gudmund
Images: 39
Postby dirtsailor2003 » Mon Feb 04, 2019 1:28 pm
Man I'd never get rid of my trusty 1966 425 Coleman! Now I have added other cooking tools like the stainless grill, and the Blackstone flat top. But I have the space so I can pack more. I also have a thing for outdoor cooking appliances. My thinks its a problem. She can't understand why I need 4 smokers, all these grills, blah blah, blah!
Nor would I get rid of my little single burner. Its a 1972 and I bought it when I was 8 for $5 in "Blind Box" deal at an auction my parents went and I went to. It came in a aluminum pot with lid. The lid turns into a pan. Never cooked in either. It also came with the heater top.
dirtsailor2003
Postby ae6black » Mon Feb 04, 2019 3:32 pm
I have the same 1 burner in the aluminum box which doubles as a pot. My goto for backpacking short distances and scooter trips.
Art
ae6black
Images: 19
Postby Modstock » Mon Feb 04, 2019 6:38 pm
Well im starting to re-think this new camp stove. Maybe I can get a small griddle , use my existing stove and clean it up. No use replacing what isn't broken. Plus that $ could go elsewhere more important.
Any small griddle's you guy's recommend ?
I found a 10.5" reversible single burner griddle that looks promising.
Modstock
Postby tony.latham » Mon Feb 04, 2019 9:48 pm
Postby dirtsailor2003 » Mon Feb 04, 2019 10:22 pm
That lodge, if kept seasoned would be great. We have one that we use at home.
Here’s a good source for buying Coleman parts. I have bought parts from them and have always had prompt service and shipping.
https://www.oldcolemanparts.com/home.php
dirtsailor2003
Postby Modstock » Wed Feb 06, 2019 12:08 am
The 10.5" fits perfectly even on our lil 2 burner, which turns out....It's not even a Coleman .
Oh well.
Man that thing is dirty.
I have some major cleaning to do. Also picked up a bag for it. Gonna sew/modify it to hold the griddle as well. ImageImage
Modstock
Postby jwlambert » Thu Feb 14, 2019 9:55 am
I use the camp chef oven and two burner stove combo(propane). Works amazing. I use them in all of my builds. I place them on a pull out drawyer...Bass Pro has them on sale from time to time. I am by no means supporting Bass Pro.
Cheers!
[https://r.search.yahoo.com/_ylt=A2KLfRpLiGVcviIApiPrFAx.;_ylu=X3oDMTEyNHEwa2FiBGNvbG8DYmYxBHBvcwM0BHZ0aWQDQjY1NzFfMQRzZWMDc3I-/RV=2/RE=1550186699/RO=10/RU=https%3a%2f%2fwww.basspro.com%2fshop%2fen%2fcamp-chef-propane-camp-oven-and-stove/RK=2/RS=9az0Xyfyv.rR5PG5KoTUx0E2ESA-][/url]
jwlambert
Postby Modstock » Mon Feb 18, 2019 7:42 pm
Link no worky.
I ended up using quick dry wax & grease remover to clean it up. Looks practically new now.
With as much as I wanted a new stove/grill combo, the aluminum turned me away. Especially since I could get cast iron going this route.
Modstock
