twinight wrote:From what I read, it's not good to mix panels. It will reduce the efficiency of the system to the weakest component. It's best to run the 24V panels through a second charge controller.
Well stated.MtnDon wrote:When there is a mix of panels the general rule of thumb is to match the Vmp and Imp values within 10%.
For panel sets in series, the Imp value (amps) should be within 10% of each other. The total current will be limited by the panels with the lowest amp output.
For panels in parallel, it is the Vmp (voltage) that should be within 10%, as the output will be limited by the panel with the lowest voltage output.
The mismatches drag the output of the highest output panels down to match the lowest values. So you need to decide if the loss is worth spending more money for more controllers so you can keep the panels in matched sets.
All that assumes the controller you have can handle to total volts, amps and watts that would be connected to the inputs.
MtnDon wrote:The mismatches drag the output of the highest output panels down to match the lowest values.
Chasein70 wrote:MtnDon wrote:The mismatches drag the output of the highest output panels down to match the lowest values.
HA HA HA HA HA HA
Chasein70 wrote: It works great.
Chasein70 wrote:HA HA HA HA HA HA
