Chasein70 wrote:If I put 24 volts into my charge controller instead of 12, does 12 come out the other end to the batteries?
That being a PWM system, does it have the buck / boost conversion capability to allow 24V panels (Voc ~40) feeding a 12V bank, or 12V panels (Voc ~20) feeding a 24V bank?featherliteCT1 wrote:My Bogart SC2030 charge controller automatically reads and accepts so called “12 volt” vs. “24 volt” panels (maximum 30 amps); however, a switch must manually be set for 12 volt vs. 24 volt battery systems and another switch must manually be set for AGM vs. flooded batteries.
John61CT wrote:That being a PWM system, does it have the buck / boost conversion capability to allow 24V panels (Voc ~40) feeding a 12V bank, or 12V panels (Voc ~20) feeding a 24V bank?featherliteCT1 wrote:My Bogart SC2030 charge controller automatically reads and accepts so called “12 volt” vs. “24 volt” panels (maximum 30 amps); however, a switch must manually be set for 12 volt vs. 24 volt battery systems and another switch must manually be set for AGM vs. flooded batteries.
