Questions, Questions, and more questions
Postby TAILGATINGnNUT » Sun Aug 15, 2004 8:42 pm
1. I have seen several people refer to LUAN, what is it?
2. When building your floor, do you build a sub floor then lay the 1/2 inch plywood on top?
3. DO you treat the bottom of the wood with anything as to say it from rottinG?
4. What size pieces of wood do you use to frame up your insides?
5. Is it necessary to insulate ther trailer?
6. After putting the wall up , i have seen many people refer to the inside wall. whats the difference?
6. Mike I noticed that your baja was a "pretty" white. How did you achieve this?
7. With all of the thgns that I want to install in mine electronically, would I be able to install a betterey and run a generator? or wuld I be better off just running a generator,. Its kinda funny everyone wants to go camping in it now. one problem its not even built yet!!!!!!!!!!!!
8. What size walls should I be using on my tailgater (not the one you designed mike) a 5x10 design of my own with a lot stolen from your idea
Im also leery of building the rounded edges and the hatch. I think I will keep my first one real simple
ANY RESPONSES TO THESE ARE GREATLY APPRECIATED
Looking to build the ultimate tailgating machine, anyone help me?
TAILGATINGnNUT
Postby catrinka » Sun Aug 15, 2004 8:49 pm
This question I know the answer to. It is a type of wood, similar to mahogany. Because it comes from a tree that grows in the rainforest it has a lot of moisture in it, thus it tends to repel moisture.
catrinka
Images: 43
Postby JamesW » Sun Aug 15, 2004 8:58 pm
You usually buy it in the form of plywood. Home Depot carries it in 1/4 and 1/8 inch thicknesses. They come in 4 x 8 sheets. I am using 1/8 inch for the skin on the wall, roof and ceiling.
JamesW
Postby tom » Sun Aug 15, 2004 9:23 pm
Heck...I thought Luan was a girl from Tiajuana...LOL
tom
Postby TAILGATINGnNUT » Sun Aug 15, 2004 9:23 pm
When you say skin where is that going?
TAILGATINGnNUT
Postby JamesW » Sun Aug 15, 2004 9:25 pm
It goes on the "bones". See my pictures. After you frame the walls for more support you insulate the wall between the frame. The "skin gets attached to the wood you use for framing. I used 1 x 2's.
JamesW
Postby tom » Sun Aug 15, 2004 9:25 pm
You know in all honesty you might want to but Kuffel Creek's plans for the Comet...The author of the plans answers all if not most of your questions..lots of pictures...lots of explaining...good set of plans..
tom
Postby TAILGATINGnNUT » Sun Aug 15, 2004 9:29 pm
I thought thats what this baord was for???? asking questions?
TAILGATINGnNUT
Postby tom » Sun Aug 15, 2004 9:35 pm
Hey just tryin to help...
tom
Postby Scooter » Sun Aug 15, 2004 9:44 pm
LUAN plywood, also known as "door skins."
The RoadCamper the old teardrop
Scooter
Images: 69
Postby beverlyt » Sun Aug 15, 2004 9:53 pm
Tailgatingnut,
I understand where Tom is coming from! Even with a set of plans, I had more than enough questions!
The plans just make your trailer building experience a whole lot easier...at least they did for us. We didn't have any building experience and couldn't have got along without them.
Bev
P.S. Ours is insulated and I wouldn't be without it.
beverlyt
Images: 20
