HF trailers
HF trailers
Postby hmike » Fri Apr 26, 2019 2:42 pm
I know I've seen instructions concerning making a Harbor freight trailer non foldable but can't find it. I'm sure it was a long time ago, can anyone help? thanks.
hmike
Re: HF trailers
Postby hmike » Fri Apr 26, 2019 7:26 pm
Thanks, it makes good sence. I thought the original guy mentioned cutting one of the center rails to use on the sides and replacing with wood. Think I'll go with angle iron and not dwell on it. thanks.
hmike
Re: HF trailers
Postby Woodbutcher » Sat Apr 27, 2019 7:34 am
Here is what I did. I removed 2 of the cross braces. They fit right inside the side channels. Bolt those across the seam and replace the cross brace with 3" angle iron.
Woodbutcher
Re: HF trailers
Postby hmike » Sat Apr 27, 2019 4:04 pm
Thank you. I may have seen your idea before, seems familiar. looks like the answer to my situation.
hmike
