* There's been a lot of discussion about Timbren axle-less suspensions on this forum for several years...how'd you miss it?
- earliest TnTTT mention of Timbren.JPG (22.76 KiB) Viewed 2102 times
* If you have the money and the need for one (heavy trailer, offroad usage, desire for independent suspension, though a torsion axle has that too), it's probably the way to go. I wouldn't hesitate to put one on a HF, or NT trailer, if I was so inclined; but I'm old school, and stayed with my familiar leaf-spring axle, for several reasons, though I did add a Timbren-esque, hollow bump stop component to my suspension, so perhaps my next set-up (if ever) might use a Timbren.
Edit: as I said, I'm old-school, and have used leaf spring axles exclusively, had hangers tear loose, spring leaves break, and had axles overloaded to the point that they bent into acute negative camber. But, all of those problems were fixable, and with parts locally sourced most of the time, within hours. I've only had to outsource when I replaced the entire small axle I had on my TTT, with a made-to-order 3500 lb Dexter. When I had previously decided to replace both of my axles on the tandem axle car-hauler (after a 10 ton front-loader bent both axles), I only had to drive by a parts dealer on the way to where my trailer was, and bought all the parts needed at once, out of stock on hand. Probably couldn't do that with a Timbren, at least not here in N.Texas. And, when I put together my TTT's Dexter set-up, I chose 3k lb springs from a wide assortment that TSC, Northern Tool, and Redneck Trailer Supply all had in stock, within 10 miles of my house, each about $25 (at that time). I could've changed them out within an hour, if I had needed to. Parts availability is great, using leaf springs.
