Mounting gas or water jugs ?
Postby Modstock » Tue Sep 03, 2019 8:34 pm
My TD was built on a harbor freight frame and the bracket (behind the wheels) never got cut off.
I was thinking about using it somehow to carry gas or water jugs.
While it would help me shift some heavy weight (100 lbs) . Im not sure how it would look.
Anybody ever do this ?
Sent from my H1611 using Tapatalk
Modstock
Re: Mounting gas or water jugs ?
Postby Greg M » Thu Sep 05, 2019 12:46 pm
I’d be worried about shifting weight behind the axle and lightening the tongue too much. A light tongue makes for a squirrely tow.
Greg M
*Geek Extraordinaire
Images: 85
Postby Modstock » Thu Sep 05, 2019 9:21 pm
I'll keep that in mind. The tongue is a bit heavy right now. Can barely lift it to move around.
My HF tongue jack didn't come with a caster wheel .
I finally ordered one for it yesterday.
Modstock
Postby Sparksalot » Sat Sep 07, 2019 3:52 pm
Modstock wrote:My TD was built on a harbor freight frame and the bracket (behind the wheels) never got cut off.
I don't see why you can't use the brackets, then cantilever the water jugs forward over the wheels. That gets the tongue weight lower without adding any behind the axle.
Sparksalot
Images: 687
Postby Modstock » Sat Sep 07, 2019 6:30 pm
Currently im thinking about the same thing. Mounting it as close to possible to the axle . Also would keep down the mud spray on the jugs.
Probably a small mud flap bolted to the fender will help.
Usually we get water at our last gas stop when we can.
Looking at gas can mounts today but my water jugs are a bit longer so that's out.
Oh well I'll keep looking around.
Just checking what those 6 gal water jugs fit.
An Ammo box gave me some idea's.
Modstock
Postby Sparksalot » Sat Sep 07, 2019 7:04 pm
Modstock wrote:Currently im thinking about the same thing. Mounting it as close to possible to the axle . Also would keep down the mud spray on the jugs.
Are those the 40mm ammo cans?
Sparksalot
Images: 687
Postby Modstock » Sat Sep 07, 2019 7:14 pm
I think it's the 30mm.
Was thinking of cutting em down a bit.
Modstock
Postby Sparksalot » Sat Sep 07, 2019 11:06 pm
Here's a sample of my stock. I have two each of the 40mm (orange marks) and the taller 120mm cans.
157260
Sparksalot
Images: 687
