truck camper tie downs?
Postby theskyking123 » Tue Sep 24, 2019 6:52 pm
Any tips on truck camper tie downs for a light-weight foamie truck camper?
theskyking123
Re: truck camper tie downs?
Postby RJ Howell » Wed Sep 25, 2019 6:30 am
My topper is only bed rail wide so I just glued (and wrapped) plywood strips to the bottom.
I have C clamps in place now so it's easy to remove.
Best pictures I found..
RJ Howell
Images: 36
Postby RJ Howell » Wed Sep 25, 2019 6:38 am
If you going full build and slide-in unit, I saw someone on YouTube utilizing his tailgate pin as a mounting point and turnbuckles to tighten. Have no idea how he held the front down.. Yet he didn't go over the cab with his, so maybe some sort of cleat/catch up front, but that's a guess on my part..
His was also a lift top (tilt lift) so it didn't look boxy going down the road and still had a area to stand in.
You have any concept drawing or pictures of what your thinking of doing?
RJ Howell
Images: 36
Postby 2bits » Fri Oct 18, 2019 9:46 pm
I had an ARE camper top and another camper top and I just used bolts and big washers going through the bed rails on 4 points.
Thomas
2bits
2bit Member
Postby swoody126 » Sat Oct 19, 2019 6:46 am
my mind's eye instantly saw a set of straps like held the hoods down on early 1950's european roadsters when i saw your cap
they were leather and many were decorative as well as being utility items
¿ box ? ... we don't knead no stinkin box to thimk in ;-)
sw
swoody126
