Overhang
Overhang
Postby TerryB89 » Sat Oct 05, 2019 8:26 pm
On a foamie, how many inches could I have the plywood over hang the steel frame?
TerryB89
Re: Overhang
Postby Pmullen503 » Sun Oct 06, 2019 7:04 am
Depends a little bit on your floor. Mine overhangs two feet but I have a built up floor of 1x3 solid wood frame covered with 1/4" ply, both sides, glued and screwed.
If you are using just sheet ply I would limit that to a foot. Make sure you wrap the canvas down the sides and under the floor for a few inches. The canvas is what ties the floor to the walls.
Pmullen503
Images: 67
Re: Overhang
Postby TerryB89 » Sun Oct 06, 2019 2:55 pm
ok, perfect, I just need about 4 inches on each side so that sounds good.
TerryB89
