Renogy compact 100w panel vs standard 100w panel
Postby Vtec44 » Tue Dec 17, 2019 4:27 pm
On paper, they're a few inches shorter but it's a big difference when you put them side by side. Both panels weigh about the same, 16.5lbs, and have similar operating/open circuit voltage/amp. The compact version is about $13 more expensive but it's a good option if you want to maximize the use of space.
Edit: These are both monocrystalline panels.
160826
Vtec44
Re: Renogy compact 100w panel vs standard 100w panel
Postby GPW » Wed Dec 18, 2019 6:26 am
just curious , how much should we add to the $13.00 ??? :thinking:
Postby Vtec44 » Wed Dec 18, 2019 6:51 pm
GPW wrote:just curious , how much should we add to the $13.00 ??? :thinking:
One is about $100 and the other one is $113 . :D
160826
Vtec44
Postby GPW » Thu Dec 19, 2019 4:55 am
Oh Not bad at all , a dollar a watt !!! 8) :thumbsup: Thanks VT !!!
