That’s Burt, the owner of Vistabule Teardrops. He has set a high bar in both teardrop design and quality.mrcreepy wrote:I've been looking for options to add crossbars to my Riverside Whitewater Retro 509, and came across this video on YouTube. It's for a different brand of trailer, but I think this could be adapted for pretty much any trailer with rv molding/trim.
I would love to hear input from others on this setup.
He modifies the square bolts for Yakima Skyline Towers designed for a flat roof and inserts them into the trim pieces. I'm not 100% sure about the internal structure of my tear, so I like the idea of not drilling additional holes fishing for a suitable mounting location.
Parts List:
Landing Pads: #8000221
Skyline Towers: #8000148
Roundbar SL Adapters: #8003536
66" Roundbars: #8000410 (Note: Depending on width of trailer you may need a different length bar)
Here's the video (skip parts info section and go to about 2:58 in the timeline to see modifications and install)
https://www.youtube.com/watch?v=oU9pnNPzsWE&feature=emb_title
tony.latham wrote:That’s Burt, the owner of Vistabule Teardrops. He has set a high bar in both teardrop design and quality.
I would trust his rack method.
T
...with realist things like sheer loads...
nbcarey wrote:I would talk to Yakima's customer support and get their engineers buy-off and load recommendations.
I'm imagining that aluminum trim (extrusions) might have... less than optimal engineering properties with realist things like sheer loads than one might like with a couple hundred pounds sitting on it, atop of 6- inch or so moment arm.
When you hit the brakes at 60 or 70 mph, suddenly and hard, and the stuff on your rack decides that it needs to continue on at that speed whilst the rest of your rig comes to a stop....
The results may be unpleasant.
A ticket for failure to secure your load at best. Injury or death at the worst.
Pmullen503 wrote:I would be okay with this system if when carrying anything like a canoe or kayak, you have a tight line from the bow of the boat down to the frame to take any lifting forces. The channel is aluminum secured with wood screws, that's fine to handle the weight but you should use rope or straps to help with lateral and lifting forces.
tony.latham wrote:...with realist things like sheer loads...
We certainly need to be cognizant of the safety of others as we're cruising down the highway.
Over on a Facebook DIY teardrop group, Ryu Fukami (he's here too but I don't recall what he goes by) has posted some tests for using edge molding as anchor points for an awning.
He's got a video of the same molding attached upside down with him hanging off of it. He's using T-nuts and not the Yakima nuts that Bert is showing in his Vistabule rack video.
I don't know if the guys at Yakima would understand what's being proposed. I don't think it's an issue with the molding but how it's attached to the roof/wall system.
Squigie wrote:I wouldn't worry about that mount method, when cognizant of the situation and attaching reasonable loads.
However, if I'm grinding nuts anyway, I'm going to grind them in the style of automotive quarter-turn t-nuts. That way, I don't have to remove the trim. Just drop the nuts/plates in, rotate 90 degrees, and tighten down.
I can't find a good example, so here's a quick rendering.
Narrow enough to drop into the slot.
Corners nipped for rotation.
Long enough for full engagement in the slot, once turned.
Slightly less engagement than a square nut, but much easier to work with and still plenty strong.
Tony I've been looking at other potential hardware. Any idea what t-nuts he's using? I'd also be interested in the name of the DIY Teardrop group name. TIA
