Need something 3d printed UV stable
Postby saltydawg » Sun Nov 01, 2020 9:06 pm
Does anyone here do 3d printing with uv stable filaments?
I am using a small led light as exterior lights, they measure about 1 inch by 3 inches and I am using 4 of them. I want to put them at about a 30 degree down angle so they light the ground more than just aim outward. They come with a gasket I can take pics of, or even mail it so the shape and size would be correct.
I am willing to pay.
Scott
Lost in Maryland
saltydawg
Re: Need something 3d printed UV stable
Postby tony.latham » Sun Nov 01, 2020 11:02 pm
Scott:
I 3D print but I'm not the guy. So far just PLA filament.
The bigger challenge –-I think-- would be designing the STL file. Got a pic?
Postby saltydawg » Sun Nov 01, 2020 11:23 pm
These are the lights. I want to aim them down at a 30 to 45 degree angle. If I cant get something printed I will probably just get a 1x1 delrin or other plastic and cut it diagonal and sand them to shape. A 1 foot piece would give me more than enough to mess a few up.
Scott
Lost in Maryland
saltydawg
Postby tony.latham » Sun Nov 01, 2020 11:49 pm
saltydawg wrote:These are the lights. I want to aim them down at a 30 to 45 degree angle. If I cant get something printed I will probably just get a 1x1 delrin or other plastic and cut it diagonal and sand them to shape. A 1 foot piece would give me more than enough to mess a few up.
I think your stock part would be fairly easy to duplicate in Sketchup. But adding the desired angle would be perplexing.
I’m sure it’s doable but it’s over my CAD skills.
Postby saywhatthat » Mon Nov 02, 2020 3:26 am
https://app.prototypehubs.com/login . When wife needs blanks made for gold sand casting I believe she uses this page .thy bid on making 3D parts .the prices go from our nuts to fair. using fusion 360
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby Philip » Mon Nov 02, 2020 11:52 am
I have a 3D printer. The problems I see on a long part is separation in the layers from expansion/ contraction after the parts are made and cooling. The parts I made were a little longer than that buy a few inches. I ended up going to a commercial printer company to have mine made. The company used a resin printer. That uses a liquid bath and a laser to set the part. Much better print quality than the normal 3D printer using a stranded filament. The price was reasonable.
Philip
Images: 323
