Well renogy decided to send a 1000 watt inverter instead. I tested it and the battery was certainly good for 40 amps or so continuous running a 500 watt quartz light thru the inverter. Ever once in a blue moon the battery did not like the start up surge of the inverter, mostly after it had been sitting turned off for a few days. The charging of the capacitors in the inverter would kick in the battery high amp protection which I think is at 100 amps, which makes sense to the fact that the inverter could draw 100 amps under full load.
So I had a choice, return the 1000 watt inverter and say I want the 700... nope. Next I could have bought another 700 watt inverter, with my luck I would have gotten a second 1000 watt inverter. Yes The 700 watt only should cost 130 or so, but the 1000 costs 200 or so, I was not going to complain about the bigger inverter, but i only need one.
Next option, live with the battery every so often kicking in its protection. Nope
So what did I do like the cheapskate I am, I bought another 330 buck battery. yup my little 12 foot camper has 120 amp hours of lifepo4 battery, and 1000 watts of pure sign inverter.
A pic of the basic setup, still needs to be cleaned up, just installed for testing of the wiring for the 12 volt fuse block. Nope not over board at all.
