western traveler wrote:For me dry ice in a good cooler (outside a sleeping compartment) works well for a few days keeping frozen goods/meals frozen. Interested in hearing about battery draw on one of those units.
Lumpy Waters wrote:The 12V fridges seem to be pretty popular these days. I'm curious if anyone uses one exclusively as a freezer to make ice for beverages, store frozen goods or freeze reusable ice packs. I have a small Dometic 18L fridge which has served well for weekend trips with a family of four and for weeklong solo trips. Usually if I desire clean ice cubes for beverages, I pack it in a separate small cooler which is good for 1 or two days at the most. Though it does have a small chiller section that stays 5-10 deg F warmer than the bottom of the main section, the fridge is basically a single zone unit that can be run either as a freezer or a fridge but not both. I've been thinking of using it as a freezer for the three purposes I mentioned above. My thinking is that, with a really good, well insulated 20-30 Qt cooler, I could rotate a set of reusable ice packs once per day from freezer to cooler, maintain ice cubes for beverages, and have a little bit of room for frozen goods. Another advantage would be that the cooler could easily be secured in a bear box if needed since it is not tethered to the trailer power. Has anyone employed a similar strategy? How has it worked out for you?
GerryS wrote:I wouldn’t make ice in one
No argument it can....it just that you have such limited space. The floor of the unit , and you would need to stack on top of the trays if you wanted to keep food at the same time. You’re better off buying a bag and keeping it frozen. But, technically...sure you can do it.mtbikernate wrote:GerryS wrote:I wouldn’t make ice in one
the icemaker in mine works quite well, actually. even when I'm using the rest of it as a refrigerator. the icemaker has fairly low capacity, though. fine for having ice for your drink on a hot day, but not really enough for much else. also, given that the ice maker module has its own power control, I don't think I'd use the icemaker unless I was on shore power or was certain my solar capacity was more than enough to keep my battery charged.
GerryS wrote:No argument it can....it just that you have such limited space. The floor of the unit , and you would need to stack on top of the trays if you wanted to keep food at the same time. You’re better off buying a bag and keeping it frozen. But, technically...sure you can do it.
Users browsing this forum: Westy and 3 guests
