Bolt Size
Bolt Size
Postby Capebuild » Fri Apr 16, 2021 12:50 pm
I'll use carriage bolts to hold the cabin to the chassis frame. I'm planning on 1/2 inch... but wondering if that diameter bolt is large enough.
Can someone recommend if this is adequate or should the diameter bolt be larger. It's holding the cabin to the chassis ... want to make sure it's got enough holding power.
thank you.
John
Capebuild
Images: 130
Re: Bolt Size
Postby eLink » Fri Apr 16, 2021 1:03 pm
You will probably hear a lot of different opinions on this, but I think most people use only 3/8" dia. carriage bolts (or elevator bolts). I used 12 of them along with torque washers.
eLink
Images: 142
Re: Bolt Size
Postby QueticoBill » Fri Apr 16, 2021 1:41 pm
Nothing wrong with 1/2" but if its holding wood, its many times stronger than the wood. A lot of study and engineering in grad school showed for wood, a 5/16" grade 2 exceeded the strength of the wood it was holding.
QB
QueticoBill
Images: 22
Re: Bolt Size
Postby noseoil » Sat Apr 17, 2021 7:51 am
3/8" is more than enough. Carriage or elevator bolts are fine for this application. Here's a chart. I used 3/8" bolts, but a single 1/2" grade 5 bolt would be fine.
164847
137905
noseoil
Images: 670
Re: Bolt Size
Postby QueticoBill » Sat Apr 17, 2021 8:10 am
The wood being the weak spot, more smaller bolts better than fewer larger bolts.
QB
QueticoBill
Images: 22
Re: Bolt Size
Postby Philip » Sat Apr 17, 2021 8:36 am
My rule is never carriage bolts to mount anything. They might be nice you don't need to hold the other side when you tighten. But the trade off is if you ever need to remove said carriage bolts. Once the nuts/bolts get rust on them. They only spin in what ever they bolted down.
I use bolts only. Working most of my life as a maintenance person. I can't tell you how many thousands of carriage bolts I have had to cut off. Laying under something with a torch, cutting off carriage bolts leads into learning new words to call the engineer that made the decision to use them.
Philip
Images: 323
Re: Bolt Size
Postby Pmullen503 » Sat Apr 17, 2021 8:58 am
Agree on the use of carriage bolts, especially in wood. They are a one time fastener. I would recommend some grade 8 bolts for their superior rust resistance.
Pmullen503
Images: 67
Re: Bolt Size
Postby Capebuild » Sat Apr 17, 2021 9:28 am
Thank you all for your comments and help. Grade 8 hex bolts it is. Makes sense about being able to tighten from both ends and they seem to have more tensile strength than carriage bolts.
Thanks again. You learn something every day. :)
Capebuild
Images: 130
Re: Bolt Size
Postby gudmund » Sat Apr 17, 2021 11:38 am
used to be grade "8"s $$cost$$ so much more than 2's 0r 5's, but now 'not' so much more = why not grade "8"s ................... :roll:
gudmund
Images: 39
Re: Bolt Size
Postby QueticoBill » Sat Apr 17, 2021 12:57 pm
The reason I would not use Grade 8 is because it is no better than Grade 2 if used to anchor wood. The wood will fail first. As a life long designer, over design just feels inelegant to me. I just like things strong enough, around a design factor of 5, and inbalance.
QB
QueticoBill
Images: 22
Re: Bolt Size
Postby PCO6 » Sun Apr 18, 2021 7:36 am
Grade 2 or 5 x 3/8" bolts should be fine. I'd also use a fairly large OD flat washer on the wood side. I've used fender washers of about 1.5" OD on things like this.
PCO6
Re: Bolt Size
Postby GuitarPhotog » Tue Apr 20, 2021 9:58 pm
The all-aluminum body and angle iron frame of my 1948 teardrop are held to the 1-1/2" angle iron frame with eleven 10-24 machine screws and square nuts. One every 12 inches of the 10 foot length. It hasn't moved in 73 years. You are building an airplane not a house.
My $0.02 worth
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: Bolt Size
Postby PCO6 » Wed Apr 21, 2021 7:11 am
GuitarPhotog wrote:The all-aluminum body and angle iron frame of my 1948 teardrop are held to the 1-1/2" angle iron frame with eleven 10-24 machine screws and square nuts. One every 12 inches of the 10 foot length. It hasn't moved in 73 years. You are building an airplane not a house.
My $0.02 worth
<Chas>
:beer:
LOL! Whatever works! :thumbsup: I've built off road race cars and used Velcro to hold some of the aluminum body panels on. They never separated even in a roll over.
In the words of the late Colin Chapman regarding lock washers ... "why would I give them a free ride around the track?". Meaning it's better to keep the weight down in non-critical places.
PCO6
Re: Bolt Size
Postby Capebuild » Wed Apr 21, 2021 4:52 pm
after quite a bit of back and forth thinking about this I'm going to use elevator bolts. at the beginning of this conversation I did not know exactly what elevator bolts were. Since then I've give quite a bit of thought about this (being a big decision). I realized I didn't like the hex bolts sticking up so much the way they do. And I do like the elevator bolts lying somewhat flat against the floor surface. So there we have it.
John
Capebuild
Images: 130
Re: Bolt Size
Postby sagebrush » Thu Apr 22, 2021 7:09 am
I used twelve 1/4-20 self tapping flat head trailer deck screws. Left overs from my trucking days .
Will
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
