James9324 wrote:I have been planning on designing my trailer with the skeleton 3/4 inch walls, insulating the sides and then covering each side with a 1/4 inch plywood so the walls would be approx. 1.25 inches thick. I was talking with someone about this who was just shooting down this idea of insulating walls but only doing the floor and ceiling.
I am wondering everyone's thoughts on this. Pros and Cons. Are there any advantages to insulating or not.
My original thought was for weight control, get rid of some plywood and replace it with lighter insulation.
I would appreciate any opinions.
Thanks
I was talking with someone about this who was just shooting down this idea...
I do have the 12mm marine ply walls and it is fine in my climate but I think insulation is never a waste and if your design allows for it then do it.MickinOz wrote:If you have the time, patience and money, insulate.
Here in Oz, things are slightly different.
Materials are expensive and hard to find.
In the end I went with solid walls, made from 17mm pine plywood.
This was not a massive problem on Saturday night, softwoods do resist heat transfer a bit.
The big issue is the doors! My doors are aluminium framed, full glass (actually polycarbonate I suspect). They are highly heat conductive. They get wet!
But they also help with fixing the problem.
Having an inner screen door with security mesh, I simply opened the solid leaf during the day, leaving the screen door locked, and let the air circulate. Dry in no time.
The next one (currently chasing a suitable trailer) I am considering using 12mm marine ply - hardwood.
Hardwood is much denser than pine. It has slightly less than half the insulating value of the same thickness of pine ply.
This might be more of a problem.
Tends to depend where you live too. Not many sub zero nights here where I live.
Socal Tom wrote:I think a lot depends on the climate where/when you camp. My TD has solid 3/4 plywood walls. I generally camp when low temps rarely dip below 50F, and the highs are usually above 70F, and the climate is very dry. So I've generally got a fan going, and vents and windows open, so condensation isn't a common problem. When it does happen, It warm and dry so it dries out quickly. I have a contingency plan for when I do camp in the cold, and that is custom cut blankets ( walmart fuzzy blankets) that I can affix to the walls with magnets.
