John61CT wrote:To use for what purpose?
Pmullen503 wrote:Are you going to sew up something or try to cover foam with it? Looks like it would be tough to glue.
dbhosttexas wrote:Keep us posted on this! I am curious to see how you deal with the pop up. You are trying to address leakage issues right?
RJ Howell wrote:dbhosttexas wrote:Keep us posted on this! I am curious to see how you deal with the pop up. You are trying to address leakage issues right?
The duck cloth works great in normal downpours. When we get those 'tropical' pours it's just too much water and the cloth wicks the water. Now this is only at one point at the bottom where I have a fold and secure the cloth. You'd think that wouldn't amount to much, but... oh does it! Second point of contention is the front windows.. Because my 'loft', extension over the cab, only goes halfway the splash back in a tropical downpour hits almost the entire front panel. It's just too much water on my windows and it wicks through.
This material does not wick!! That should cure the initial issue I'm having. It's thicker/stronger than any other ripstop nylon I have used before and this coating is supposed to be one of the best. So far it sews well with these microtech needles which the thread just fills the needle hole nicely. I'm also working through doing an awning above each window with the same material on the idea of how the rooftop tents do it.
Modstock wrote:Well if the Otter-tex dosent work out there is K-tex. We use it at my work for Dump truck covers, semi trucks, boom covers, ect.
Very strong and water aint getting through it but you'll need a industrial machine to sew it up or have a upholstery shop that works with this sew it up for you.
If you go this route, I can help. Shoot me a PM.
Sent from my SM-A115AP using Tapatalk
Users browsing this forum: DezPrado and 5 guests
