saywhatthat wrote:is there something binding the movement in the rest of the lock?
Try squirting a little WD40 in the key hole
that not the best WD-40 will hold dust and dirt and eventually clog up your Tumblr if it dose . try flushing out with rubbing alcohol. What we see happening is somebody will
spray this type of lubricant in and then gets a little bit of dirt and dust till D
gets a little bit hard to turn so they'll keep spraying more and more until finally plug the whole thing up.
AS these are new this is not your problem.
halfdome, Danny wrote:Sorry to see several WD40 naysayers but years ago the latch on my 55 Chevy passenger door wouldn’t latch right. Someone on a form suggested WD40 and it worked like a champ and I never had to spray it again.
It’s basically fish oil & invented in San Diego California.
Graphite is excellent too.Danny
Socal Tom wrote:halfdome, Danny wrote:Sorry to see several WD40 naysayers but years ago the latch on my 55 Chevy passenger door wouldn’t latch right. Someone on a form suggested WD40 and it worked like a champ and I never had to spray it again.
Actually WD40 is mostly DMSO.
dose not attract dirt or moisture to metal surfaces – just be sure to wipe off any excess WD-40® M
Myth: WD-40® Multi-Use Product should not be used on bike chains.
Fact: While WD-40® Multi-Use Product it is not a grease, it is formulated with strong lubricating oils and other ingredients, and is a terrific product to use for bike maintenance. It does not attract dirt or moisture to metal surfaces – just be sure to wipe off any excess WD-40® Multi-Use Product before riding.
For long-term lubrication and other specialized bicycle maintenance needs, check out WD-40® BIKE. Developed specifically for cyclists and mechanics, this high-performance line of bicycle care products is sure to become a mainstay in the toolboxes of bike mechanics for decades.
