Flip out camper
Flip out camper
Postby JasenC » Sun Nov 21, 2021 12:03 pm
Anyone seen this, just ran across it on youtube.
I've been thinking about an expandable camper during my design stage, pop up or slide out, but had decided to KISS for my 1st one.
I hadn't though about doing it like this though, he even built a coroplast roofing system. Not so sure about that, but if it works for him.
Can't remember the trick for embedding youtube links.
https://youtu.be/WW0pkPhkBb8
167709
167710
167708
I'll be done when I'm finished, if that's not fast enough, take a number.
Build Thread https://www.tnttt.com/viewtopic.php?f=50&t=74269
JasenC
Images: 122
Re: Flip out camper
Postby WizardOfOdds » Mon Nov 29, 2021 8:27 pm
I posted a few comments about his build in my “unusual designs” thread, with links to all 3 of his videos.
My posts are at at these links:
https://www.tnttt.com/viewtopic.php?f=5&t=64495&start=75#p1208679
https://www.tnttt.com/viewtopic.php?f=5&t=64495&start=75#p1211926
https://www.tnttt.com/viewtopic.php?f=5&t=64495&start=105#p1245434
In case the links don’t take you to the exact spots, home in on them by the post dates:
Fri Jun 30, 2017 11:44 am
Tue Aug 08, 2017 6:54 am
Thu Mar 14, 2019 10:43 pm
Read the limited comments I have in the above posts, and be sure to expand and read the comment on Youtube pages.
The major issues I have with his design are the roof, setup and tear down in bad weather, and I would worry a bit about stability when opening in strong wind:
About his roofs, I don’t remember many shots of his tarp top, and dread to think of trying to install it in the wind or rain. I think his panel roof is actually the stuff used for green houses (poly-carbonate ??) as it seems to be clear and cost so much (did he say $400 with the aluminum parts??) Skylights are nice but a see-though roof would be WAY TOO HOT in the sun! Coroplast should be a good bit cheaper but probably needs more support.
If I were to seriously consider building it, I would spend a lot of thought on the roof. It looks like he has a very slight slope, not enough in my opinion. And if I went tarp, I would try to figure some way to insulate it and have it roll out fast and easy in wind/rain.
I always wondered what he did with the mattress etal when he flips the bed over. Also, older folk like me might find the bed a bit too high.
But there are some obvious draws:
lots of room, stand-up area, walk-in door with head room, and a big window for air at the bed.
When folded, not very tall and light weight too! Pretty hard to beat all that! Interesting.
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 43
Re: Flip out camper
Postby JasenC » Tue Nov 30, 2021 2:12 am
Not the route I'm going on my first one.
Definitely not a foul weather set up.
Although I already have a good rough idea how to do a proper roof. haha
JasenC
Images: 122
