Vintage Vespa Teardrop build complete - videos / photos
Postby tburick » Mon Nov 29, 2021 9:35 pm
First, I'd like to thank the members here who gave me some great advice as I was going through this build.
The total finished weight of the teardrop is a mere ~170lbs and it tows behind the vintage Vespa fairly well. The limitation is actually the trailer...when I thought for sure it would be the bike. The 150cc 2-stoke motor pulls strong and the manual transmission definitely helps while towing. Even the bike's dual-drum brakes do a good job stopping the trailer. The limitation is the solid axle on the trailer. When I hit a sizeable bump or pothole it will sometimes bounce the trailer wheel(s) a couple inches off the road. I found that adding some cargo over the axle helps...as well as trying to avoid road imperfections.
I had the trailer out over the Thanksgiving weekend for some camping. Video below. There's closed caption commentary if you click the "CC" button in the YouTube viewing window. There's also a link in the description box if you are interested in seeing the "tour/reveal" video.
https://www.youtube.com/watch?v=wzGYiUVkqqM
tburick
Images: 30
Re: Vintage Vespa Teardrop build complete - videos / photos
Postby pchast » Tue Nov 30, 2021 11:40 pm
Have you calculated the pressure 'required' for the full
trailer weight including occupants?
:thinking: I was able to reduce the tire pressure in my tear's
tires enough to reduce rebound on the road and still provide
enough for control and support.
pchast
Images: 97
Postby tburick » Wed Dec 01, 2021 7:28 pm
Well...the problem is the tires are foam filled / non-pneumatic. What I'll probably do at some point soon is find pneumatic replacements. I'll post back after the solution :thumbsup:
BTW - anybody know why were hating on Spam???? :stompspam:
It's my favorite camping food in the entire universe :FNP
tburick
Images: 30
Postby Tom&Shelly » Wed Dec 01, 2021 7:43 pm
tburick wrote:Well...the problem is the tires are foam filled / non-pneumatic. What I'll probably do at some point soon is find pneumatic replacements. I'll post back after the solution :thumbsup:
Mine too! Read somewhere that it causes dementia, but I don't remember where.
Of course, this smiley thing is for the other type :stompspam: a lot of which seems to be fellows from China trying to sell us stuff like industrial aluminum.
Oh, also, I read somewhere Spam can cause dementia. (But I don't care!) :thinking:
Tom :lol:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby Tom&Shelly » Wed Dec 01, 2021 7:48 pm
Seriously, though, great trailer, and I really like your video! Bet you'll have lots of fun with it!
Tom :thumbsup:
Tom&Shelly
Images: 2282
Postby cluttonfred » Sun Dec 05, 2021 2:07 am
Great-looking trailer and nice video, thanks for sharing. A couple of questions:
—What trailer did you use as the foundation for the build?
—How did you keep the weight so light? Did you follow a particular set of plans?
—The trailer lights did not appear to be connected in the video. Any trouble connecting those to the Vespa?
Matthew
Matthew Long, Editor
cluttonfred.info
A site for builders, owners and fans of Eric Clutton's FRED and other safe, simple, affordable homebuilt aircraft
« Voici ce que j'ai fait...vous pouvez en faire autant! » "This is what I have done...you can do the same!"
--Henri Mignet (1893-1965)
cluttonfred
Postby Cosmo » Sun Dec 05, 2021 4:13 pm
Great video. Thank You
=Cosmo
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Postby tburick » Sun Dec 05, 2021 7:56 pm
Cluttonfred,
My friend and I built the trailer frame from from scratch. It's made of aluminum and with the tires and axle weights only 26 pounds.
I did not follow any plans. I designed the trailer. There's a lot of aluminum, foam, canvas, glue, ash wood, and other super lightweight materials used in the construction process.
The trailer lights are not currently connected. A 1962 Vespa does not have a battery as part of it's electrical system. The electrical system largely relies on OHMS to operate...it's incredibly crude...even for a 1960's vehicle. I barely understand it...it's a process to even figure out headlight and tail light bulbs without causing other bulbs to pop when it's time for bulb replacement. I might just turn the trailer tail lights into constant ultrabright flashers with an onboard trailer battery and call it good.
COSMO - thank you for the compliment! It's appreciated.
tburick
Images: 30
Postby Capebuild » Mon Dec 06, 2021 7:10 am
what a great video.... and really cool trailer!
How long does it take to cook the hen the way you set it up? Thanks.
John
Capebuild
Images: 130
Postby tburick » Mon Dec 06, 2021 8:25 pm
Capebuild,
Thanks for the compliments.
I cooked the Cornish Game Hen for 2 hours on very low heat. I turned the stove burner down to almost the point of it self-extinguishing.
Keep in mind that hen was stuffed with homemade stuffing but even at that, 2 hours was overkill. If I had to do it again, I'd probably cook it for 1.5 hours.
Nothing saying you couldn't do it for the full two hours though. The bird was juicy and the meat just fell off the bone.
Wrap firmly in 3 layers of parchment.
Enjoy!
tburick
Images: 30
Postby Capebuild » Tue Dec 07, 2021 7:37 am
I showed my wife the video (which she also loved).. but we both were interested in the cooking of the bird. I thought using the stones to elevate the meat was very ingenious. You must be a fan of Julia Child with the generous butter application :)
I raise my own meat birds so always interested to see how others cook their's .... especially during travel/camping escapades.
John
Capebuild
Images: 130
Postby tburick » Tue Dec 07, 2021 7:57 pm
I'm glad you guys liked the video. I don't know how apparent it is, but I have full text commentary if you hit the close captioning "CC" button. Did you happen to catch that or did you watch without any text commentary?
EVERYTHING IS BETTER WITH BUTTER :lol:
tburick
Images: 30
