OTTTB - Over The Top Trailer Build - Where is it???
Postby BuildingOurDayDream » Sat Feb 26, 2022 10:38 pm
Someone highly recommended this thread, but after a search I'm coming up empty. Does that thread exist on this forum (if so you'd know it apparently)? If not, must be a different forum.
BuildingOurDayDream
Re: OTTTB - Over The Top Trailer Build - Where is it???
Postby bdosborn » Sun Feb 27, 2022 11:25 am
Whoops!
Images: 806
Postby S. Heisley » Sun Feb 27, 2022 6:51 pm
BuildingOurDayDream wrote:Someone highly recommended this thread, but after a search I'm coming up empty. Does that thread exist on this forum (if so you'd know it apparently)? If not, must be a different forum.
Based on your first comment on this forum (above), you probably insulted half the builders here because, based on their opinion, theirs's is over the top. There are hundreds of beautiful builds here. Maybe you don't have the patience to look through them all. That, I can understand. Do you even know what exactly you're looking for? The one that I think is over the top is fairly close to the top (but not the first page) in the Build Journals section but I'm not going to make it super easy for you. I'll give you a few hints and you can go on a treasure hunt. First, if you think you may have hit on "The One", go to the last page of that journal and work your way backwards. Second, here is the video of the first part and the title is listed within. https://www.youtube.com/watch?v=OGN_EJm6rLs
Happy Hunting!
Postby aggie79 » Tue Mar 08, 2022 1:33 pm
There actually was a cargo trailer conversion with such a name (or close to this name). One unique aspect I recall is that he had the wall plywood installed on the outside of the framing instead of the inside of the framing. I need to scratch my head and see if I can recall anything else about this build.
Postby aggie79 » Tue Mar 08, 2022 1:35 pm
I just found it. The name was "Over The Top Cargo Trailer". Here's the link: https://www.tnttt.com/viewtopic.php?p=843713#p843713.
