Tom&Shelly wrote:I don't believe in "best by" dates. Note they aren't "expiration dates" like medicines (which I also don't necessarily believe in).
I've eaten soups and stews that were 13 years past their "best by" date and they were fine. Of course, look and smell first, then cautiously taste, but you should always do that anyway to make sure there weren't undetected punctures in the can. If food does "go bad" it's more likely to be unpalatable than to make you seriously sick. That's really what the "best by" date is about.
We had lots of "emergency cans" of food that we used during the covid supply shortages. We've since replaced them, but emergencies just don't happen often enough to comply with the "best by" dates all the time.
Tom&Shelly wrote:Oh! I did recently discover Loktite has an expiration date of only about 6 months. On something important, that's one I'll pay attention to from now on!
S. Heisley wrote:While camping recently, I managed to pinch my finger so badly that everything above the first knuckle turned blue and I got a big blood blister on its pad. I continued setting up and the blister eventually broke open. I put on a band-aid to keep it and my camp stuff clean. However, the band-aid only lasted a couple hours before it came loose. The same thing happened with the next band-aid...and the next. When I got home and was talking to a friend, she mentioned that the "use by" date could be found on the bottom of the package. Sure enough, it had an expiration date of 2/2022. Were those band-aids old when I got them? I don't think so but.... I bought replacements and the date on the bottom of those is 2/2024 so I'm guessing that they've found a way to shorten the life of the band-aid adhesive
dmb90260 wrote:Look at canned foods. If the can top/bottom looks like it is swollen, toss it. The same goes for any thing in bottles, sauces and such. Bottled water does not go bad but it can taste funky. I have earthquake suppies and swap out the water over time. It is still great for the plants. l have dry camp food that I need to check occasionally but most lasts a very long time.
rjgimp wrote:Alkaline batteries.
halfdome, Danny wrote:Good topic.![]()
We recently bought a tube of Gorilla Glue construction adhesive and nothing would come out after several puncture’s of the seal, ended up throwing it away.
Going to check for dates on things like that from now on.Danny
S. Heisley wrote:Consider Bear Spray. I'm bad. I know mine is expired and could start leaking, which would be a mess. I wonder if it'll even spray if I need it. That stuff is expensive! At many national parks, you can rent it and save yourself $ as well as the headache of wondering if it's good.
