I am building a minimalist 5x10 TD using an aluminum snowmobile trailer. Unfortunately the way the trailer is reinforced I couldn’t move the axle back into an optimal position. So I am using a tongue box and careful weight distribution to balance front/rear weight and ensure a safe pull.
My question - is weight distribution as important on a lightweight trailer (less than 1000 pounds anticipated) and does the ratio of 10-15% tongue vs trailer weight still hold true? I ask in part because it doesn’t seem to matter that much how I load my utility trailer unless I have something heavy like gravel in it.
Thanks much!
Bret
