Fire Extinguisher Recommendations
Postby Capebuild » Tue Jul 12, 2022 11:46 am
I just went through an interesting thread regarding "where" to place a fire extinguisher. I'm asking if anyone can recommend
any particular brand and any other "important" features I should be on the look out for prior to purchasing one.
Thanks
John
Capebuild
Images: 130
Re: Fire Extinguisher Recommendations
Postby gudmund » Tue Jul 12, 2022 12:30 pm
my 5lb fire extinguisher along with a fire blanket is in my tongue box. I see others mounting them inside the bed area of the trailer or galley - my logic for the tounge box = it's located at a halfway point 'if/when' needed between the tow vehicle and trailer, along with if I was to have a fire = the plan is to "get away" from the fire - thus having the fire extinguisher in a 'neutral' 1/2way middle point for easy access 'if and when needed'. (also carry a 2.5lb between just inside the driver's door/seat).
I have never liked the thought of having to 're-enter' a burning 'bed/galley area' trying to retrieve a pre-mounted fire extinguisher if that area is on fire - would rather be able to get out & away first - then return to fight the fire if able too so...... (when during our group trailer outings/crawls - I would normally pull the 5lb 'out of' the tongue box when camped, hooking it to it's outside hook mount on the box, then informing others in our group of it's location for it's use if need be..........)167722 the 'fire extinguisher' decal showing it's location and red mounting hook can be seen here on the side of my tongue box.....
gudmund
Images: 39
Postby Modstock » Tue Jul 12, 2022 12:49 pm
Avoid the "Kiddie" brand fire extinguishers.
Sent from my SM-A115AP using Tapatalk
Modstock
Postby halfdome, Danny » Tue Jul 12, 2022 3:59 pm
John, we keep our fire extinguisher in the tongue box.
It's a Kidde 5-B:C Automotive Dry Powder Fire Extinguisher.
What I highly recommend is the First Alert Smoke Alarm: 3V Lithium, Photoelectric, 85 dB @ 10 ft, LED Visual Alert, Hush Button.
It’s very small and has a piercing sound that can’t be ignored.
It chirps occasionally to verify battery health.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby swoody126 » Tue Jul 12, 2022 5:34 pm
ABC / Marine (brand of choice)
one inside the bedroom door near the latch
and one in the kitchen area opposite the stove
sw
swoody126
Postby KCStudly » Tue Jul 12, 2022 5:42 pm
A maintenance note on dry powder type extinguishers; make it a routine to not only check the charge on it, but to also invert it (turn it upside down) momentarily before putting it back on its holder. The powders can settle and clump over time, making them less effective. By flipping them over occasionally the powders should stay loose.
Postby gudmund » Tue Jul 12, 2022 7:26 pm
Danny just brought up the "chirping" low battery alarm sound, about a year or two ago when my trailer was stored during the winter, when I was outside walking by it - I would hear a distance 'chirping' sound every so often, I would stop looking around the yard thinking, 'that is a different sounding bird I have never heard before', wonder where is it hiding at? After a month or so later, I had the door to the trailer open one day and heard it again, but louder = which is when I realized what it was. :? :o :o
gudmund
Images: 39
Postby MickinOz » Tue Jul 12, 2022 7:46 pm
KCStudly wrote:A maintenance note on dry powder type extinguishers; make it a routine to not only check the charge on it, but to also invert it (turn it upside down) momentarily before putting it back on its holder. The powders can settle and clump over time, making them less effective. By flipping them over occasionally the powders should stay loose.
I do that when I remember. Sometimes you can actually feel a "thud" as the clumped up powder lets go.
MickinOz
Postby rjgimp » Tue Jul 12, 2022 9:52 pm
Modstock wrote:Avoid the "Kiddie" brand fire extinguishers.
What's the reason for that? I've not heard bad reviews before and most places around here, that is the only brand available.
-Rob
rjgimp
Images: 7
Postby GPW » Wed Jul 13, 2022 6:20 am
Is there a way to rig up a tube to the FE nozzle to direct it at a certain area ... Say one is mounted outside with a tube directed inside ... :thinking:
Postby dmb90260 » Wed Jul 13, 2022 8:21 am
Dennis
Join the Kenskill Karavan at:
http://autos.groups.yahoo.com/group/kenskill_karavan/
Real Men cook with Black Iron
The Buzz In the Dale: The Buzz In The Dale
dmb90260
Titanium Donating Member
Images: 134
Postby bdosborn » Wed Jul 13, 2022 9:19 am
I got mine at Home Depot, it's DOT rated and has a bracket to strap it down.
Kidde 1-A:10-B:C
Images: 806
Postby Modstock » Thu Jul 14, 2022 5:12 pm
There was a recall a few years ago and most places are just selling what's in stock.
Modstock
