fredo wrote:so if you stick to the 40/60 split to locate your axle, how does that apply to a torsion axle where your trailing spindle is actually several inches away from where your mount is? (I'm thinking the half axle flexride) does this make a difference in handling?
fredo wrote:so I was inquiring about the weight of the flexiride I wanted to buy and I asked the guy from certain axle seller and he said the mounting plate/torsion box was where I needed to base my weight loading on. hmmmm
