Trailer suggestions
Trailer suggestions
Postby McFish1951 » Tue Nov 19, 2024 6:27 pm
I want to do a 6 x 8 foamie; I have a utility trailer with a ramp and side rails already. But it weighs about 750 lb bare. Does anyone have a recommendation for a lighter frame? It must be 6 x 8 or longer.
McFish1951
Re: Trailer suggestions
Postby QueticoBill » Tue Nov 19, 2024 7:19 pm
Not wanting to build your own? 750 sounds very heavy. Does that include rails, ramp, and deck?
QB
QueticoBill
Images: 22
Postby MonteQuest » Tue Nov 19, 2024 10:59 pm
I found that you are better off building your own frame. Axle location is very important. Look at my frame in the Build Forum: Monte's Ramblin' Rose. The weight and costs are detailed, including the axle.
Monte
Monte
MonteQuest
Images: 63
Postby rjgimp » Sun Dec 01, 2024 10:15 pm
A foam cabin for a trailer that size would only add about 100 pounds. :thumbsup:
-Rob
rjgimp
Images: 7
Postby McFish1951 » Sun Dec 01, 2024 11:04 pm
There is a gate, as well as 2x8 floor boards. Based on someone else's post, the gate is about 100 lb; and .75 in plywood in lieu of 2x8's would save about 75 lb. Ideally I could bolt the floor of the cabin directly to the frame, thereby skipping the trailer floor. If I do that, I would have to add a skirt piece of foam and PMF, sort of like what the "road foamie" build has, for a drip strip.
McFish1951
Postby Modstock » Tue Dec 03, 2024 1:36 am
Do you have any pics of it. If it were me, I'd keep it and start shedding pounds. Better to have a stronger frame.
If it has thick wood slats. Replace it with plywood. Could also remove the sides and the ramp unless you want those.
I have a friend that cut down the ramp and used it to haul stuff on like coolers, firewood, ect. It folds up when not in use.
Sent from my SM-A115AP using Tapatalk
Modstock
Postby McFish1951 » Tue Dec 03, 2024 12:08 pm
The rails are integral to the strength of the frame. I plan on removing the drop down rear gate/ramp. If I lose 75 lb by replacing the 2x8's and 100 lb from the ramp, I'm at 575 lb for the frame. I am mobility challenged; ie can't crawl around and get dressed without more than 45 inch headroom. So I plan to have a rear door into a 72 inch high cabin. the rear 3 feet is 72" high, then it slopes to the front where it is 48 inch or maybe less. This helps aerodynamics.
McFish1951
Postby martymcfly » Tue Dec 03, 2024 10:19 pm
So, you might want to build something like this only maybe a little taller? https://www.youtube.com/watch?v=SACbs2ihxRc The trailer with the fold down ramp might be handy for you.
martymcfly
