Applying Foam Board
Applying Foam Board
Postby Dahlia47 » Sun Jan 12, 2025 12:33 pm
Ill be using foam board to insulate. I used it for the roof. Works great! I also get it free. But...when I use regular glue, it melts the board where the glue was applied. I'm applying the foam board to plywood. Is there a glue out there that won't melt the foam board?
I'm also going to use wallpaper on top of the foam board.
Dahlia47
Re: Applying Foam Board
Postby foxontherun » Sun Jan 12, 2025 12:48 pm
Good morning,
I have no experience with gluing foam but ran across this website: https://gluesavior.com/what-glue-to-use-with-foam/.
Perhaps it will be useful for what you are doing. Good Luck!
Harry :)
foxontherun
Images: 91
Postby Dahlia47 » Sun Jan 12, 2025 7:08 pm
Thank you!
Dahlia47
