complete design
complete design
Postby Chip » Tue Aug 24, 2004 1:45 pm
Ya know I read a lot of how different folks build or are gonna build their units,,I suspect that most have or will do as I have and over compensate in every aspect of building,,In my case , my frame use to carry a full 12'x6' old, heavy popup. even though the frame has been cut down to 9'-2"x55" it still has all the same parts and structure the original had,,walls, framing etc are a lot stronger than conventional camper construction,,the rest is by hip pocket engineering,,the point I am getting to is it would be real interesting, enlightning and maybe a bet spooky to see the results of a full engineering design of a teardrop,,loads,vertical horizontal, shear, electrical design per camper codes, mechanical design to include dew points in walls, ceilings and floors, and how much ventilatio in cfm etc is really required per standards that cover campers,,most of the decesions that are made reguarding windows etc are on looks rather than on how many sq in of vent area is needed,,
what ya'll think,,any engineers, arch, mechanical designers electrical engineers or someone with contacts that is curious as to what tha numbers really say???? just thinking ,,,again
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Jiminsav » Tue Aug 24, 2004 9:08 pm
you know, your dangerous when you think, Chippy..if we had real smart people looking at these thing, the price would go up. 8)
Jim in Savannah
Jiminsav
Images: 40
Postby Shrug53 » Tue Aug 24, 2004 10:05 pm
Plans? We don't need no stinkin' plans!
"Better living through reckless experimentation"
http://www.forgottenclassics.com
Shrug53
Postby mikeschn » Wed Aug 25, 2004 4:08 am
We don't need any kits either. Every teardrop we build is scratch built! More fun that way.
Hmmmmm.... we could add some levels here on the board... Level 1 means you've built 1 teardrop. Level 2 or 2nd Teardrop club means you've built two, and the ultimate expression of the addiction that is teardrops... "Certified Level 3" born again Teardropper!
What's beyond Level 3? That's easy. Just look at Cary's or Grant's level!!! :lol:
Postby Chip » Wed Aug 25, 2004 5:02 am
I just hope Ralph Nadar never sees a teardrop,,,can you emagine having to get a building inspector to check off each step ya do,,,and to sell one ya got to get a termite letter,,Damn,,,I gonna quit thinking and shut up and go sit in tha time out corner for a while,,,life was so easy when I had things to do on the TPO tear,,now my life is empty,,it must be gorilla glue withdrawls,,,theropy,,yep thats what I need ,,professional help,,??????????
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby BufordT » Wed Aug 25, 2004 5:19 am
Chip wrote:I just hope Ralph Nadar never sees a teardrop,,,can you emagine having to get a building inspector to check off each step ya do,,,and to sell one ya got to get a termite letter,,Damn,,,I gonna quit thinking and shut up and go sit in tha time out corner for a while,,,life was so easy when I had things to do on the TPO tear,,now my life is empty,,it must be gorilla glue withdrawls,,,theropy,,yep thats what I need ,,professional help,,??????????
chip
Only help for you Chip is Build another tear!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bufordt :twisted:
"RUSH" The Man, The Legend, The Way Of Life.
BufordT
2nd Teardrop Club
Images: 23
Postby mikeschn » Wed Aug 25, 2004 5:29 am
Chip wrote:life was so easy when I had things to do on the TPO tear,,now my life is empty,,it must be gorilla glue withdrawls,,,theropy,,yep thats what I need ,,professional help,,??????????
chip
Buford is right of course... you need to join the 2nd teardrop club. BUT... and this is a big but.... you need to stretch out your project so that it lasts about 2 years. By then you might have your fill of building teardrops. If not, well then you'll have to become a teardrop manufacturer and join the ranks of folks like Grant and Cary.
Too many teardrops, too little time!
Postby BufordT » Wed Aug 25, 2004 5:59 am
And Mike,
He's on his way with the 3rd. So Mike What's the name of your teardrop company?
Bufordt :twisted:
BufordT
2nd Teardrop Club
Images: 23
Postby mikeschn » Wed Aug 25, 2004 6:06 am
If I still feel like building after the third one, I'll have to go into business for sure... Hmmmm what to call the company...?
Too many tears, Inc?
:lol:
Postby Chip » Wed Aug 25, 2004 6:33 am
how about " BAJA BUCKS" Corp
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby mikeschn » Wed Aug 25, 2004 7:22 am
BufordT wrote:
Chip wrote:,,yep thats what I need ,,professional help,,??????????
chip
Bufordt :twisted:
So what are you going to build next Chip?
Postby Chip » Wed Aug 25, 2004 7:45 am
Mike,,funny ya should ask,,a sketch that was posted during the contest has got me intrigued,,I dont remember who posted it but it was a mini MANOR,,,aluminum sides with rounded edges,,all rivited together,,just sketching now but it would definately be different,,5x10x4'6 high,wrap around front split window, porthole in side,,???I think it could be built,,
a mind is a dangerous thing to use!!!!!!!
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby mikeschn » Wed Aug 25, 2004 7:52 am
Oh, you must be thinking of that one that Joanne drew up for us...
http://tnttt.com/viewtopic.php?t=606
Good project. That'll keep you busy!!!
Postby Chip » Wed Aug 25, 2004 8:14 am
thats it,,,,
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby mikeschn » Wed Aug 25, 2004 8:32 am
So what chassis are you going to start with this time? Another popup? A H.F. 4x8? Something in between? LOL
