Which is why it is currently on the burn pile.
We tried several things to salvage it, none of which were successful, so we decided to scrap it and try again.
I believe our main issue was spring back. We used 3/4 inch ply wood for the outer ribs, doubled up. with ripped 2 x 4's for horizontal ribs. We skinned it with 1/8 inch luan, and it sprung back on us, we couldn't get it right so we're starting over.
So now we're thinking about different materials, we thought about redoing the frame out of wood again, and using a more flexible skin that won't spring back on us. But, I'm building a woodie, so if at all possible I'd like to maintain that look on the hatch, and I don't feel comfortable just rebuilding the same hatch and hoping it doesn't spring back.
So then we thought of using 1/8 x 1 inch steel angle iron for the outer ribs, and possibly pre welding a strap of flat steel which would span the curve of the hatch. This design would hopefully be impervious to springback. Again thinking of ripped 2 x 4's for the horizontal ribs.
I guess I'm wondering if anyone else has used angle iron for their hatch frame, did it work? Was it difficult to attach a plywood skin to it? Any stories or suggestions would be much appreciated. Once we get this hatch figured out I can just tell it's going to be smooth sailing from here on out (*crosses fingers*).
Thanks for reading.
