Larry C wrote:Chuckles,
I still suspect the varnish your using as being the problem.....
IMO/ epoxy does need protection from UV, but using consumer grade "spar urethane" varnish is not the way. For UV protection you want a true marine grade spar varnish. Costs more per quart, but less per year of service. The four tried and true varnishes that qualify are: Epifanes Gloss, Interlux Schooner, Pettit Captain's and Flagship. Consumer grade single-part urethane resin is more susceptible to damage from UV than the traditional resin's. The spar urethane adds the UV protective additives to get back to "acceptable", while the marine grade uses the additives to increase protection and extend longevity. You won't find the real marine finishes at ordinary paint stores. Here's a good source: http://www.jamestowndistributors.com/userportal/search_subCategory.do?categoryName=Varnish&category=36&refine=1&page=GRID
