Build your hatch in place and skin it, then cut your hatch?
Postby Junkboy999 » Tue Dec 03, 2013 3:24 pm
check out the build blog. He built his hatch and skinned it in place along with the back of his teardrop. Next he use a dremel with a side cutting bit to cut the hatch loose.
http://colestear.blogspot.com/2013_03_01_archive.html
Junkboy999
Images: 52
Re: Build your hatch in place and skin it, then cut your hat
Postby KennethW » Tue Dec 03, 2013 8:25 pm
That is what I did. the hatch and the doors.
110013
110010
It worked for me.
KennethW
Images: 82
Postby tony.latham » Tue Dec 03, 2013 10:02 pm
I built my framework in place as per Steve Frederick's Build Manual suggested and skinned it after it was off. Worked great. It was easy to locate the reinforcements for the supports while in the teardrop but unskinned. No springback.
I sweated over the hatch during the entire project, but it was rather simple, thanks to following Fredrick's Build Manual. :beer:
Postby eamarquardt » Wed Dec 04, 2013 9:25 am
That fellow's hatch looks like it would survive a thermonuclear blast. Overkill in overkill mode. :applause: :thumbsup:
Gus
eamarquardt
Images: 150
Postby aggie79 » Thu Dec 05, 2013 10:26 am
I built the framework and skinned the outside of my hatch in place, but I did not have to cut it loose. The way I did this was to have a framed bulkhead - later to be insulated and skinned both sides - instead of a solid plywood bulkhead. I used screws and spacers to temporarily attach the framing. I also waited to cut the "notch" for hatch/sidewall weatherstripping until after the hatch was built. I "released" the hatch by crawling from the cabin through the bulkhead framing into the galley area and then removed the temporary screws. Here are a few pictures:
