Over engineered or under-thought?
Re: Over engineered or under-thought?
Postby AGM_AU » Thu Feb 27, 2014 9:28 pm
rowerwet wrote:my tear is entirely built with PLPremium (which may not be sold or sold under the same name in other countries), no screws staples or nails. each joint was screwed together with drywall screws to dry, then the screws were removed and the holes filled. I used the "internal chine log" method. anywhere you want two panels to join you put in a block of wood, 1" wide on the glued face, with one glued face on each panel and every joint oozing PLp to make sure it was full for waterproofing.
While I like it and it is waterproof, I don't know if it saved me much money over marine epoxy and fiberglass tape joints, and it is heavier than epoxy and glass. If I ever build another plywood tear it will be with epoxy and glass joints, that way no joint needs extra wood to reinforce it, and my spars could be made of 1/4" plywood. Super light like a modern stitch and glue boat, or airplane structure design.
I'll have to revisit some of my uncles gear and see if any of his books of trade are in there (restoration Shipwright). I remember the same technique on some of the smaller boats he had restored (the larger were all Pitch & Oakum sealed). Fibreglass was one option I'd looked at, but wasn't my first choice. LOL....I've used in the past, but we never seem to play nice 100% of the time, and my success has varied.
Thanks Rowert :thumbsup:
Favourite Quote of all time:
"Here is elegant proof that the Gene Pool needs more Chlorine at the "Shallow end". :)
AGM_AU
Images: 18
