I am looking for a simple to make construction table
Re: I am looking for a simple to make construction table
Postby halfdome, Danny » Sun Mar 16, 2014 12:56 pm
jonw wrote:
halfdome, Danny wrote:This isn't the simplest to build but it's the best I've ever worked on.
I bought a motorcycle lift table plan and modified it to my own needs.
It's in the lowest position (13" from the floor) and raises several heights up to 34" with the aid of an automotive floor jack.
The slot in the base is for a pallet jack so it can be moved anywhere, loaded or empty.
Got rid of the fork lift as it's not needed with this bench.
Using the trailer floor that's mounted to the chassis for your bench will kill your back.
:D Danny
Great idea Danny! Where did you get the plans you used?
Jon, This looks like the website where I purchased the plans.
I made a base out of 4" x 4" lumber and covered it with 3/4" plywood & plam so I could move it around with my pallet jack.
The top is made out of a 2" x 4" frame, plywood and trimmed with matching plam.
I masking taped a 4' x 8' sheet of rigid cardboard to soften it so my projects don't get damaged from wood & metal shavings, etc.
It's has been strong enough to lift my new Chevy 350 CI crate engine for my 55 Belair. :thumbsup:
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby mallymal » Tue Mar 18, 2014 6:04 pm
For an el cheapo solution, but one that's very flexible, why not buy the sprung clamps that make saw horses like this
http://t.harborfreight.com/pack-of-2-sa ... yjPspIgGSM
You can make the legs a custom length for yiur own comfort, and you could use a 4' wide horizontal piece of lumber on each, then just drop an 8x4 sheet on as your table top. The beauty is it's infinitely variable in the size you make depending on the length of those horizontal crosspieces....
Just a thought :thumbsup:
mallymal
Images: 18
Postby VijayGupta » Tue Mar 18, 2014 10:16 pm
Would this work for you? http://www.popularwoodworking.com/artic ... box_system
Note there are plans and cut lists at the bottom of the page.
VijayGupta
Postby bobhenry » Wed Mar 19, 2014 7:03 am
Here is a great knock down table.
