Wall to ceiling roundover
Postby Forrest747 » Mon Oct 13, 2014 9:40 am
When building my trailer i used a 1/2 inch roundover so that i could use fiberglass tape. So i took different sizes of baltic birch plywood to see the profile at different wall thicknesses. the roof panel was .12 inch baltic birch and to simulate spars i used 1x2 poplar. the different wall thickness in inches are .71 .46 and .37. i used liquid nails as the adhesive. once the panels had set i ran them on my router table with a 1/2 inch roundover router bit.
at .37 there was a gluing surface of .26 left over.
at .46 there was a gluing surface of .37 left over.
at .71 there was a gluing surface of .63 left over.
so on average you lose about .09 inches of material from the .12 roof panel
any strength you lose from plywood joint would be more than compensated by using fiberglass tape to reinforce.
125246125245125244
took in account for a .71 interior and a .12 exterior with a .12 roof. same 1/2 inch roundover many of the cookie cutter profiles use this setup.
125286125285
Forrest747
Cowbell Donating Member
Images: 447
Re: Wall to ceiling roundover
Postby Tommy2tone_1999 » Wed Oct 15, 2014 7:47 am
Great illustration
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
