Roof Plywood Thickness Under Aluminum - How Thick?
Postby Tommy2tone_1999 » Tue Oct 28, 2014 3:53 pm
I will be using luan plywood for my roof. I will seal it with CPES, then I will be rounding the seams and sealing them with fiberglass tape followed by painted 0.04" aluminum. My question is how thick should my roof be under the aluminum - will one 1/8" sheet of luan be enough or do I need to go with 2?
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Re: Roof Plywood Thickness Under Aluminum - How Thick?
Postby tony.latham » Tue Oct 28, 2014 5:25 pm
Tommy2tone_1999 wrote:I will be using luan plywood for my roof. I will seal it with CPES, then I will be rounding the seams and sealing them with fiberglass tape followed by painted 0.04" aluminum. My question is how thick should my roof be under the aluminum - will one 1/8" sheet of luan be enough or do I need to go with 2?
In Fredrick's Build Manual, he says one layer of 1/8" is fine under aluminum, but two layers if it's not sheathed. In my experience (build #3), 1/8" baltic birch ply is fine (('m backing mine with pink or blue foam which really strengthens it up) under .040 aluminum
