My walls will extend to the top and sit flush with the top of the frame - basically the frame will be visible once the walls are complete and sheathed with aluminum. I know to seal the bottom edges of everything with Epoxy - but I have seen some builds and manufacturers put some kind of aluminum trim along the bottom as well, like the Moby 1:
Any ideas what to use down there? I want to make sure that bottom edge gets sealed up nice and tight, but without extending the aluminum down to cover the frame (for aesthetics mostly).
