Sorry to be asking loads of questions but it seems to be the sensible thing to do.
This question has several parts.
Firstly before I learned of "the mix" I paid way to much for an acrylic timber sealer that does the same job in 2 or 3 coats.
I tested it and wet some ply and timber off cuts with 2 coats and the water just beads .
I'm going to coat it with 1 coat of poly aswell on the skins.
So with that said is it feasible I can glue canvas directly over those skins with sika wood glue (pretty much the same as titebond but cheaper here) and paint without using resin on the joins?
I'm looking at painted sides and aluminium sheet roof/front/hatch and don't want viable canvas seems at the wall tops how best to join so the seems on the root?
I'm sort or thinking out loud as much as asking for ideas but I want to build it to last so help or ideas very much apreciated
