I've read pros and cons to flipping the axle, so I still need to research that, lower would give us more height which is good because we are both tall! I also need to consider if I want to move the axle back a bit, the plan is to extend the frame with 2x4's machined down to match the frame to a total of 5x10, using construction adhesive and bolts. Put 1/4" ply on the bottom and seal it with epoxy paint (like they use on drift boats).
Once I'm past that, I was planning on putting some stringers in to beef up the gaps in the interior frame, fill it with insulation, and then use a 3/8 ply to lay the subfloor.
This is going to be a ton of fun and my wife and I are doing it together, I have extensive word working experience, so I'm not worried about that part, it's the things I've not played with before like laying out the subfloor that concern me. There's so much information here, it can get overwhelming...
Let the Madness begin!!!
Thanks
-Paul-
