Wiley Window gluing glass to fiberglass
Postby dogscats » Tue Sep 15, 2015 2:38 am
I will soon be receiving two fiberglass Wiley windows frames. Each frame has two pieces of glass one Wiley the other one is fixed . The manufacture has informed me they will not have the fixed glass retaining ring .The soonest they will have the tooling is February.
My question is the frame has a reset for the fix glass. Can the glass be glue and not need the ring .
The Wiley open is 14''wide by 11''. The fix is a arc shape 14'' by 7'' high.
I know there a locking gasket. But that over my head to do
IF you done this what glue did you use?
How hard any tricks ?
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Re: Wiley Window gluing glass to fiberglass
Postby KCStudly » Tue Sep 15, 2015 12:29 pm
I think more info is needed. It sounds like you are referring to a manufactured assembly. How about a link to the supplier's info?
Postby dogscats » Wed Sep 16, 2015 12:30 pm
NO web site . The molds where built Buyer pass way. Then sold again new buyer fount out the up front cost in Calif was more than they come up with . So now they have a lot of parts. At this time they just bundled the parts required to do the out side shell. Selling on eBay.
I need to find a good glue . May try a Glass and Tile Drill and bolt it in.
dogscats
Images: 20
Postby daveesl77 » Wed Sep 16, 2015 4:36 pm
I'm old and may not be understanding this post, but are you saying you have purchased two wiley windows. In one window the glass (clear pane) is fixed and cannot be opened and with the other the glass does open?
If this is the case, then something is wrong. The purpose of the wiley is so that it can be fairly easily closed, opened at an angle or completely open by removing the pane. The pane is normally held in place by triangular pieces on each side of the frame, cut at the same angle as the frame. To close, you just push the pane against the inside wall and slide in the triangles behind it. To have the angle open, you lean the pane back against the outer edge of the frame and insert the triangle between the pane and the wall. To fully open, you just slide the pane out of the frame. Some have gone so far as to add in "risers", so that the pane can be both opened at and angle and slid up some for even more ventilation.
If the pane is just permanently sealed then it isn't a wiley, it is just a non-opening window.
I have four wiley windows in mine. The frames are glued to the inner walls. Since mine was wood to wood, I used TB2 to mount the frame to the wall. They were also brad nailed in until the glue set. I then began layering 3 layers of epoxy around the frame and inside the wall and the inner wood frame. Everything was then coated with 5 layers of spar varnish. I have weird exterior shapes for mine, which is one of the beauties of the wiley design. It can look like anything from the outside, but is a rectangle with and angle on the inside. With mine, now over 2,800 miles of travel and the entire summer uncovered in the daily Florida rain storms, they have never leaked a drop. I leave at least two angle-open at all times for ventilation. If you are doing fiberglass window to a wood wall, you can use epoxy to mount.
In this one the window is angled open. I don't have the triangles in place as I was just shooting these shots during construction
131430
Window closed. Once again, the triangles aren't installed, but you can see where they go on the frame sides.
131429
The ones on my doors are slightly different and instead of side rails they each have a cross bar, but they still use the slide down triangles. I made these this way so that my 12v O2 fans can slide into them if I want and they hold a couple of little cut outs my wife made, the "Conch Fritter's Conch)
131592
dave
daveesl77
Images: 273
Postby dogscats » Wed Sep 16, 2015 6:21 pm
There one window on top of the other the top is fixed
I like the Wiley window .IF the glass breaks I can replace.
dogscats
Images: 20
