Struc 1 plywood?
Struc 1 plywood?
Postby vegask » Sat Nov 07, 2015 12:04 pm
Was calling around the other day and found a lumber yard that could get me 4x10 sheets of 15/32" Fir. She stated it was "struc 1" which I assume means structural grade one or something. Anyone familiar with this and would it be ok to use for my walls? Planning on buying 4 sheets, outer wall and inner skeleton style build.
vegask
Re: Struc 1 plywood?
Postby tony.latham » Sat Nov 07, 2015 12:39 pm
I'm not familiar with the term, "struct 1" plywood. I suspect it is CDX which may be great for sheathing a house but too many voids for teardrop building in my opinion.
I think you'll find a consensus here that 15/32" plywood is too thick (and heavy) for the sheathing parts of a sandwiched wall. I like 1/4" plywood subflooring* for the inside/outside and 3/4" AC plywood for the core of the wall. Get on the phone and ask around who has 1/4" plywood subflooring and go look at it. (Look for voids on the edges) The stuff I get here is higher in quality than 1/4" AC plywood and a bit cheaper.
* The stuff is stamped "for moist environments" and you can throw a scap in a bucket of water and it won't delaminate.
Postby MtnDon » Sat Nov 07, 2015 12:46 pm
struc 1 is meant for sheathing a building wall to give structural strength. It is not pretty; meant to be covered. Many knots showing, some with voids. Much like CDX
MtnDon
Images: 24
Postby vegask » Sun Nov 08, 2015 12:41 pm
Ok, back to the drawing board. If I were to find 1/4" AC 4x10 and use that for the exterior face, 3/4 AC 4x10 for the core, then 1/8 baltic birch for the interior, that would make a pretty decent wall correct?
vegask
Postby tony.latham » Sun Nov 08, 2015 2:33 pm
vegask wrote:Ok, back to the drawing board. If I were to find 1/4" AC 4x10 and use that for the exterior face, 3/4 AC 4x10 for the core, then 1/8 baltic birch for the interior, that would make a pretty decent wall correct?
Yep. That'll work just fine.
I haven't tried to order 10' long plywood here in this one-lumberyard town. What I did on my last build was spline join two pieces of 3/4" AC plywood and then cover those joints with the 1/4" subfloor. And if i have to build again, that's the way I'll do it. Spline joining 3/4" plywood with a router is easy and as long as you've got good plywood glued across the joint, it's strong.
