Hurricane hinge photo request
Postby ratrod71 » Sun Apr 12, 2015 6:58 pm
I am about to make my galley hatch and install it with a hurricane hinge. Can you guys please post photos of how you have the hinge terminating at the side wall and edge trim, and then the hatch edge and trim. Thanks in advance, Bryan :thinking:
Alaskan Benroy build journal: viewtopic.php?f=50&t=61738
ratrod71
Re: Hurricane hinge photo request
Postby len19070 » Mon Apr 13, 2015 1:13 am
Heres a Post I made earlier. There are many ways to do this but in the end....The one that doesn't Leak, is the Best.
I've always had a different approach to building a hatch. Instead of building heavy to prevent "Spring Back", Use materials that Don't "Spring Back" :?
I use FRP and Aluminum.
I build 2 outside rails, 1" thick (by using 2 pieces of 1/2") And cross spars. Then I cover the outside with FRP, good side in extending 1 1/2 past the rails on both sides.
FRP does not "Spring Back" and is strong enough when bowed around the hatch to not flex...as well as being stable enough to Triangulate the hatch.
I also install a second sheet of FRP on the inside, good side in as a finish.
2 sheets is more than enough, then sheath the outside with Aluminum.
I seal the outside edges with this;
I know, I know. But doesn't water get into the sides?
No! I build the sides in 3" at the hatch, and run the outside corner molding straight through. This is a very common area for leaks. The FRP/Aluminum extends 1 1/2" past the galley opening and I put a second outside insert molding on the inside of the galley.
This insert molding is 3/8" tall with a vinyl insert that acts as the hatch's seal. Plus I extend the offset Hurricane hinge past the galley opening.
For the water to get in it has to run down, make a right or left hand turn, run up hill and jump over a 3/8" tall molding that is under the FRP/Aluminum.
In addition the 2 outside corner insert moldings create a good Trough for the water to run down there by directing the water out and off the trailer.
These shots are from 3 different trailers of mine, but the theory is still the same.
Happy Trails
Len
len19070
Images: 24
Postby ratrod71 » Wed Apr 15, 2015 9:51 pm
Thank you Len for being so kind to post your photos. Anyone else want to share some pics? Bryan
ratrod71
Postby ratrod71 » Sat Jan 02, 2016 2:26 pm
Still looking for photos of hurricane hinge installation. Particularly where it terminates at the side wall trim. Thanks
ratrod71
Postby dales133 » Sat Jan 02, 2016 2:33 pm
Mines not complete yet but ive followed the general consensus of how its done and will post some pics for you shortly
dales133
Postby dales133 » Sat Jan 02, 2016 2:48 pm
This is the hatch side of the hinge detail.
Ill go get some of the body detail.
My hatch isnt currently fitted
dales133
Postby dales133 » Sat Jan 02, 2016 2:58 pm
This is the body side of the hinge.
Hope this is of sme help.
dales133
Postby ratrod71 » Sat Jan 02, 2016 6:42 pm
Very helpful. Thank you!
ratrod71
Postby dales133 » Sat Jan 02, 2016 6:54 pm
No probs,your welcome
dales133
Postby halfdome, Danny » Sat Jan 02, 2016 7:16 pm
Here's how I do it, I hope this is of some help.
You may want to check out this thread.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby les45 » Sat Jan 02, 2016 8:10 pm
Here is how I did it but mine was on a flat hatch on a weekender style TD.
I installed standard edge trim after the first two pics that simply butted up to the hinge pieces and caulked the joints. I also caulked the openings on the ends of the hinge and trim.
les45
Images: 605
Postby ratrod71 » Sat Jan 02, 2016 11:07 pm
Thanks again. I have a feeling these photos are going to be very helpful to many builders.
ratrod71
