I guess it could be overbuilt. I see many commonly sized and built teardrops or travel trailers, but the completely unique and different seem to not be so common. I have a need of a removable body, which means needed support for the lift systems. Being wider than most at 80", sitting higher up, I worry about racking and structural fatigue. I know how solid 2x4 frames feel when well attached... That is why I asked. I lurked for days, but it seems everyone has their own way. My camper will see cold temps, late October early November, can get down around 40 at night. I am not to sure how well I need to insulate it. Layers add up, once beyond the 2" thickness for walls and RV style windows, At a loss as what to do. I have not yet seen a double panned exit window.
I need to be able to walk on top of my camper, with supplies and someone else. Almost a utility deck, platform for pictures, stargazing, or my kayaks. I was thinking that about one inch or so of the 2x4s would be stained on the inside, with the pine in between those, in case I needed to remove or add insulation.
I tried forums with off-road tears or campers, they to see to have a specific system they like as far how to. I asked about finishing OSB, but that got zero replies... have you seen stained OSB as a floor or furniture? VERY interesting... I thought that would be so cool and unique for a exterior... but... all quiet over there.
Anyways, weight is not a issue for mine either. I can pull 11K, so I don't worry. My trailer is in the ball park of 1,600 lbs. currently. I need to remove stuff, and make changes to the whole trailer. If I can find a place to rework the springs, I might be able to remove about 200lbs right there... 17 leaf springs per side is a bit over kill. Old style stacks. I think I can get more modern ones and lower the deck height about six inches. Don't get me wrong, 16" of axle clearance is nice.
A few people tell me heat inside a teardrop is not really needed at about 50 degrees because the small area inside, warms with body heat. I might have four people in mine, but I am thinking more than likely, just me. Adding heat will be that much more difficult, and more weight that foam. I will check your thread out soon. Thanks for the reply..
