Front A/C Hatch
Postby Gerdo » Sat Jun 24, 2006 10:58 pm
It is/was shorter than my teardrop. I didn't have any problems towing. I did lift my 4Runner a couple of inches but not because it was shorter than my teardrop.
Gerdo
Images: 156
Postby Bandit » Mon Jul 03, 2006 11:09 am
My latest update to the A/C Hatch was to find a way to seal the A/C unit when it was extended.
I went ot Lowe's and found a 8' length of 1.5" door seal. It has a rubber 1.5" flap that I used to seal around the edge of the A/C/ unit. I also used 1" angled aluminum and cut it the lengths to the height of the A/C and slide them into the side notches for the included window fillers. This allows the A/C to slide out to a certain point, then the seals seal against the sides and no leak.
I will try to update with some photo's.
:thumbsup: :thumbsup: :thumbsup:
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
