Structure advice appreciated.
Postby Miriam C. » Thu Jul 20, 2006 12:26 pm
Hi all,
I think I need advice on how much support to give my window. The window is 42" by 26". It is an RV type.
My framing measures exactly 1" thick and 1 3/4" wide. So I left two member loose to see what everyone thought.
This is the open framing and is 16" on center with 4" on ends.
This one has 4"open on the ends and 8" between the short members
2. Question, The window has curved corners. Do I need to make corner pieces for it?
Thanks you for your advice
Aunti M
Postby madjack » Thu Jul 20, 2006 12:44 pm
...my advice is that the first framing pic is sufficient and yes you need to have curved framing for the window...
madjack 8)
Postby Chip » Thu Jul 20, 2006 12:48 pm
couldnt have said it no better,,,"DITTO"
chipper :thumbsup:
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Chris C » Thu Jul 20, 2006 12:49 pm
Uh-huh times 3!!!!! :thumbsup: :applause: :lol:
Chris :D
Chris C
Postby Jiminsav » Thu Jul 20, 2006 8:45 pm
quattro
Jim in Savannah
Jiminsav
Images: 40
Postby Miriam C. » Thu Jul 20, 2006 9:00 pm
Thank you all so much. (I am trying to not build a tank here :oops: )
I made the "little" curved pieces. The window has an outer flange and an inner Flange (don't know the right name for it) so I had to cut around the smaller inner thingy. That leaves an inner void of about 1/4" inside.
I'll post a picture tommorow. The digital doesn't do close ups.
Miriam
Postby Jiminsav » Thu Jul 20, 2006 9:02 pm
the inner flange is called a mounting ring..you did good
Jim in Savannah
Jiminsav
Images: 40
Postby Kevin A » Thu Jul 20, 2006 10:28 pm
Cinco ;)
Kevin A
The other guy
Images: 289
Postby jdarkoregon » Fri Jul 21, 2006 12:45 am
MC, the first pic most likely would be enough support, but if you wanted to add more, it would go above the window, like headers in houses, Your walls are really looking great, you make progress everytime I read your questions.
John
PS, I love the window size! I have the same size for my build in hopes of creating an open airy feel for the tear, tell me if it works,
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby Miriam C. » Fri Jul 21, 2006 11:53 am
Thanks Jim and John,
I love the window too. they had a much nicer one. It had side panels that didn't open and 4 panes that open. It was 48" across and 36" up. I came so close to taking it home. Way too big of course but it was nice.
I added 2 side braces and another wall stud toward the back. Just have one more to cut but ran out. Gotta cut another 2"x6"x10'.
I did fit the window today. SNUG. I barely left room to get it in. :lol:
Happy building
Miriam
Postby Miriam C. » Tue Jul 25, 2006 4:06 pm
Well I finally got to Wally world to get some film developed.
This is the channel in the window. I seems to sit on the outside ledge leaving a void in between. Does that sound right?
Thanks
Aunti M
Postby madjack » Tue Jul 25, 2006 9:14 pm
AM, the OUTER flange should seal against the exterior wall, the channel you are refering to should be in line with the waall and the inner flange should either come off or be for an interior trim ring to fasten to....
madjack 8)
Postby Miriam C. » Tue Jul 25, 2006 9:32 pm
Thanks MJ
I hope it lands where it is supposed to because if not I am gonna screw it in from both sides. :lol: :twisted: 8)
AM
Postby Arne » Wed Jul 26, 2006 4:33 am
Miriam, is that a new window, or rv salvage? I'm still looking for more window sources....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Miriam C. » Wed Jul 26, 2006 7:02 am
Morning Arne,
That window came from a RV in an auto salvage yard. Seems they have RV's scattered all over Joplin. I went too most in town. Also looked at conversion vans. I was thinking the tall narrow windows would look good.
Miriam
Users browsing this forum: Google [Bot] and 3 guests
