hatch spar location
hatch spar location
Postby wvmedic » Sun Mar 19, 2023 7:04 pm
I'm building my first teardrop, just starting actually. I have the template done edges sanded smooth, I was laying out the cabinets and things when I began thinking about where should the hatch start. How do I determine where my hatch needs to start? I'm using a 48" radius on the back, I'm building a 5x10. I would greatly appreciate any help.
Thank you, Jeff
wvmedic
Images: 5
Re: hatch spar location
Postby tony.latham » Sun Mar 19, 2023 9:26 pm
wvmedic wrote:I'm building my first teardrop, just starting actually. I have the template done edges sanded smooth, I was laying out the cabinets and things when I began thinking about where should the hatch start. How do I determine where my hatch needs to start? I'm using a 48" radius on the back, I'm building a 5x10. I would greatly appreciate any help.
Thank you, Jeff
Well... this works.
If you are using 5' sheets of Baltic, you want to limit the hatch so its surface doesn't go beyond 5'. And if you need a wire chase in the galley, make sure you set the spar 3" or so away from the bulkhead.
Postby wvmedic » Mon Mar 20, 2023 7:37 am
Thank you Tony, I don't know how I missed that. I'm definitely going to triple the hatch spar, probably going to use oak. I think poplar might be to soft.
Jeff
wvmedic
Images: 5
Postby Sparksalot » Mon Mar 20, 2023 6:28 pm
wvmedic wrote:Thank you Tony, I don't know how I missed that. I'm definitely going to triple the hatch spar, probably going to use oak. I think poplar might be to soft.
Jeff
I used poplar for all the roof spars on Rose, 5x10. I doubled them on each side of the fan, and at the hatch. So far so good at 15 years.
Sparksalot
Images: 687
Postby wvmedic » Mon Mar 20, 2023 7:32 pm
Thank you Sparksalot.
Jeff
wvmedic
Images: 5
