T-Moulding Install Need Help
Postby Von Pook » Fri May 01, 2009 1:25 pm
Do any of the "box" stores carry "T-molding"?
Eric, the camping sound guy
Von Pook
Images: 10
Postby Dean_A » Fri May 01, 2009 2:53 pm
Not that I've seen. You can order it from Grant, or you might check some local carpeting/flooring places.
Dean_A
Images: 55
Postby grant whipp » Mon May 04, 2009 2:46 pm
The T-Molding from the carpeting/flooring stores is not bendable, as bought ... you will need to anneal it if you want to bend it 'round any kind of radius. If you don't need to bend it, then it'll work just fine ...
Good Luck, and as always ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby 2bits » Sat Aug 15, 2009 9:51 pm
I know this is a couple months old but I think it deserves a: GTG"
Go To Grant! :thumbsup:
Thomas
2bits
2bit Member
Re: T-Moulding Install Need Help
Postby Lucky53s » Tue Jun 24, 2014 7:25 pm
Any chance of reviving this so the pictures show up?
Lucky53s
Postby kootenaytear » Thu Jul 31, 2014 4:42 pm
Lucky53s wrote:Any chance of reviving this so the pictures show up?
bump to that!
kootenaytear
Postby aabowman » Tue Nov 18, 2014 12:34 am
I'd love to see those pictures as well. haha.
(looks like the links are broken) :thinking:
-Aaron
My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives.
aabowman
Images: 7
Postby johnandtricia » Tue Mar 24, 2015 7:25 pm
Why is this even up no pictures and nothing of any real help :cry:
johnandtricia
Postby fcasavant » Mon Nov 02, 2015 4:52 pm
:? So where the pictures for this thread completely lost? Or are they available? Thanks
fcasavant
Postby Noc3 » Fri Jan 08, 2021 12:33 pm
use a flexible T molding?
Found this stuff. Thinking about using it on my build as the bottom drip edge.
https://pantherrvproducts.com/105-544-2 ... k-10-feet/
Noc3
Postby tony.latham » Fri Jan 08, 2021 2:27 pm
Noc3 wrote:use a flexible T molding?
That thread is five years old.
"...for custom made tables or countertops."
Sounds like it's for interior use only. UV rays may not be friendly.
T
Postby Tom&Shelly » Fri May 05, 2023 8:16 am
Stewered wrote:Any chance of reviving this so the pictures show up?
Show up fine from here. Why do your posts have links to irrelevant sites? Are you getting money from clicks?
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
