Hey guys, newbie here. I’ve been working on my camper project on and off for some time now. I was going for a very lightweight 6x10 squaredrop shape by simply stick framing with 1x2’s and 2x2’s, cramming all the gaps with 1.5” foamboard, then simply PMF-ing the outside and carpeting the inside. Though now after almost finishing with the foamboard i’m realizing it would be hard to get the exterior finish anywhere near smooth without some sort of flat plywood sheathing first. Also, i think the extra rigidity wouldn’t hurt. So i want to cover the entire outside with some sort of thin plywood or similar before doing PMF all around. I’m not really relying on the plywood for structural support, and it should be protected from the elements by the PMF, so what would you guys recommend I use? i’m on a tight budget so the cheap Tri-PLY underlayment type paneling is calling to me but i’m not sure if that’s going to be a bad idea. Not sure where to get thin baltic birch around my area, and it looks expensive… Thanks in advance.
